メインコンテンツにスキップ
この分解は修理ガイドでは ありません。 お持ちのScotch TL901を修理する際は、iFixitの修理ガイドをご利用ください。
  1. The Scotch TL901 Laminator
    • The Scotch TL901 Laminator
  2. Using a small Phillips screwdriver, remove the screws from the bottom of the plastic case.
    • Using a small Phillips screwdriver, remove the screws from the bottom of the plastic case.
    • Rubber feet in the four corners must be removed first to gain access to the screws underneath. A sticker may also be covering the middle screw on the left.
  3. Pull off the silver plastic cover and gain access to the internal components.
    • Pull off the silver plastic cover and gain access to the internal components.
    • The rollers, motor, circuit board, and LEDs are all visible now.
  4. First unplug all three wire headers connected to the circuit board.
    • First unplug all three wire headers connected to the circuit board.
    • Unscrew the two screws holding down the circuit board by its corners and remove the board from the laminator.
  5. Unhook the spring from the plastic surrounding the motor.
    • Unhook the spring from the plastic surrounding the motor.
  6. Hold the roller enclosure from both sides, indicated by the markers, and pull upwards and slightly out.
    • Hold the roller enclosure from both sides, indicated by the markers, and pull upwards and slightly out.
    • Free access to the motor and rollers is now possible.
  7. Remove the motor from the rollers by unscrewing the three screws holding them together.
    • Remove the motor from the rollers by unscrewing the three screws holding them together.
  8. Remove the sensor from the roller enclosure by unscrewing the two spring-loaded screws.
    • Remove the sensor from the roller enclosure by unscrewing the two spring-loaded screws.
  9. Unscrew the two screws and the bar on the other.
    • Unscrew the two screws and the bar on the other.
  10. Pull the black washers sideways off the metal rod of the roller.
    • Pull the black washers sideways off the metal rod of the roller.
    • Pull the gears off.
  11. With the gears off, the plastic panel falls off and the rollers come out of the enclosure. The laminator is now disassembled.
    • With the gears off, the plastic panel falls off and the rollers come out of the enclosure.
    • The laminator is now disassembled.
Calvin Xu
メンバー登録日: 2013年04月18日
190 ポイント
1ガイドが承認済み
チーム
F14BraunReverseEng F14BraunReverseEng人のメンバー
Community
2 メンバー
8のガイドは作成済み
Why is the screw on the left side so hard to get out?
Teri L Geist - 返信
Thank you..
Putting it back together is more of a challenge.
Frank - 返信
You're right Frank. For me, getting it to stay together after the tear down and reassembly required superglue and two extra screws. ;) But at least it's working again. Thanks for the great instructions.
pjcall975 - 返信
Thank you! Just needed to open and remove a jam. Followed your guide and all is well.
KQuinn
Kate Quinn - 返信
Thank you for posting these instructions. I was able to remove a quarter that got trapped inside.
seanretzloff - 返信
コメントを追加する
統計データを表示:
過去 24時間: 14
過去 7 日: 55
過去 30 日: 195
今までの合計 17,014
