メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのSamsung Wireless Charging Padを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Samsung Wireless Charging Pad Teardown, Grab your wireless charger: 手順 1、 1の画像 1
    • Do not remove the rubber ring on top, the adhesive may weaken (alike mine, which barely sticks on) when you attempt to replace it.
  2. Samsung Wireless Charging Pad Teardown, Flip the Charging Pad over: 手順 2、 1の画像 1
    • Flip your Wireless Charging Pad over, noting the position of the Qi logo (Bottom right of label)
  3. Samsung Wireless Charging Pad Teardown, Using the Jimmy tool: 手順 3、 1の画像 1
    • Use your Jimmy tool to pry in between the two clear plastic layers. Try to keep the Jimmy's tip pointed upwards as you push it into the Charging pad, and the rounded side down (Relative to the Qi logo).
    • Now slide the jimmy up gently until it stops.
  4. Samsung Wireless Charging Pad Teardown, Separating the cap and Midframe: 手順 4、 1の画像 1
    この手順で使用する道具:
    購入する
    • Without removing the Jimmy tool, rotate the top (still upside down) clockwise, and the bottom counter clockwise. The two pieces will separate from each other.
    • Take note of the location of this tab, as seen held by the Reversed Tweezers. Mine broke off because I was too rough bending it back up, but you might need to lightly bend it up to retain the chargers ability to stay closed during transport.
  5. Samsung Wireless Charging Pad Teardown, Using the Screwdriver: 手順 5、 1の画像 1
    • Remove the four marked screws from their holes with your small screwdriver...
  6. Samsung Wireless Charging Pad Teardown, Don't lose your screws!: 手順 6、 1の画像 1
    • ...Making sure that you place them in a screw tray or safe place of sorts until you are ready to reassemble the Charging Pad.
  7. Samsung Wireless Charging Pad Teardown, Separation of the Midframe and Base: 手順 7、 2の画像 1 Samsung Wireless Charging Pad Teardown, Separation of the Midframe and Base: 手順 7、 2の画像 2
    • Gently separate the two pieces. Here you will find the powerboard.
    • Warning: DO NOT try to remove the powerboard unless you intend on resoldering the charging coils. The back of the power board is completely blank, so the only replaceable components are the chips on the face you see here.
  8. Samsung Wireless Charging Pad Teardown: 手順 8、 1の画像 1
    • Reverse these steps to reassemble the Charging Pad, and plug the pad in upon completion to test the functionality. Congrats, you've successfully disassembled the Samsung Wireless Charging Pad
作成者
2人の作成者と共同で作成されました。
Brant Arab
メンバー登録日: 04/11/17
187 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 14
過去 30 日: 130
今までの合計 13,695
