はじめに
Teardown showing all the guts of an old Samsung T139 flip phone.
必要な工具と部品
Start by removing the back of the phone. Once that is done you will find 4 Phillips 00 screws two on the top left and right and two on the bottom left and right
Take out the battery
You will see 4 phillips 00 screws, two on the top left and right and two on the bottom left and right. Remove them.
Take the Jimmy and go around the sides of the phone until the outer border comes off.
Push gently on the side of the screen cable with a Spudger to release
Then remove the logic board.
Take the keyboard out by pulling gently on the side with some tweezers
Remove the two black screw covers on the bottom of the screen
Remove the two screws that are revealed
Take a Jimmy and go around it until the front case (the one with the smaller screen) comes off.
Take a Spudger and push up on the little black bar at the top end of the screen to logic board cable
Take a Spudger and push up the little red bar over the camera cable.
Pull the cable out and remove the camera.
Congrats! Your done. Let's take a look at what we have.
Outer cases
Screens
Logic board
A camera
Some button covers
A battery
A keypad cover
