必要な工具と部品
Remove the six Phillips head screws. Keep track of their position.
Using a SIM removal tool or other small point, remove the bottom antenna cover. See photo 2. Place the tool in the bottom right corner and pry it off.
Using a spudger, carefully remove the antenna cover. Remove the two screws.
Using your fingers or a spudger remove the two side buttons. Note their positions. These should easily pop off.
Remove the two screws surrounding the camera.
Remove the two screws around the top of the battery spot.
Pry the black midplate off the phone.
Carefully flip the motherboard up. Flip it from bottom to top.
Disconnect the ribbon cable with a spudger.
Pry starting at the bottom with a spudger. Remove the cover. This will require some force and a guitar pick.
Remove the daughter board and lift the small blue flex cable from the back of the LCD.
Remove just enough of the blue sticker to disconnect the orange flex cable. Flick the brown connector up and remove.
Remove the camera assembly.
Use a spudger edge around the edges of the lens. Remove carefully and use 3M to reattach.
Flick the little brown connector up and remove the orange flex cable.
コメント 1 件
My cell phone SGH a777 has lost the sound and how to correct an entry does not function.
I want to have it repaired. Where should I bring it to have it repaired?
