メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
この分解は進行中です。 – 最新版を見るには定期的に再読み込みします。
はじめに
Removing the outer casing of the Samsung SCH-U340.
  1. The U340's outer casing is held in place through a combination of screws and tabs. The screws are hidden under plastic plugs, which will need to be removed.
    • The U340's outer casing is held in place through a combination of screws and tabs. The screws are hidden under plastic plugs, which will need to be removed.
  2. After these plugs are pulled out, remove the two screws located under them. These screws are very small, so be sure to keep them safe.
    • After these plugs are pulled out, remove the two screws located under them. These screws are very small, so be sure to keep them safe.
  3. The Essential Toolkit
    コンパクト版iFixitキットの中で最も利便性の高いツール
    ショップを見る
    ショップを見る
  4. The only thing keeping the top part of the casing on now are seven tabs--one large tab (marked in red) and six smaller tabs (marked in yellow). To remove the casing, first start by removing the big tab.
    • The only thing keeping the top part of the casing on now are seven tabs--one large tab (marked in red) and six smaller tabs (marked in yellow). To remove the casing, first start by removing the big tab.
  5. Now remove the smaller tabs, doing the tabs marked in red last. After the tabs have been removed, carefully peel the outer cover off completely.
    • Now remove the smaller tabs, doing the tabs marked in red last. After the tabs have been removed, carefully peel the outer cover off completely.
  6. Removing the bottom cover is a much simpler task. After removing the four screws marked in the picture, simply peel the back cover off.
    • Removing the bottom cover is a much simpler task. After removing the four screws marked in the picture, simply peel the back cover off.
Anish Sambamurthy
メンバー登録日: 2010年02月11日
29 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 962
