はじめに
Samsung is back, baby! The world's biggest smartphone maker kicks off 2017 by launching what is very nearly the world's biggest smartphone—with its monster 6.2-inch display, the Galaxy S8+ packs a visual wallop. But how will it fare on the teardown table? Let's get the exploded view.
Oh, were you looking for our standard Galaxy S8 teardown? Well, look no further.
Want to get the edge on future teardowns? Follow along on Twitter, make friends with us on Facebook, and check out our Instagram for all the latest!
必要な工具と部品
ビデオの概要
You've seen the slick exterior of the S8+ in Samsung's promotional imagery, but we're going deeper. A few of this teardown's expected waypoints include:
6.2-inch, dual-edge, Super AMOLED display with 2960 × 1440 resolution (529 ppi)
Qualcomm Snapdragon 835 (or Samsung Exynos 8895) processor, with 4 GB RAM
12-megapixel rear camera with dual pixel autofocus and 4K video capture; 8-megapixel selfie camera
64 GB internal storage, expandable via MicroSD card (up to 256 GB additional)
IP68 water resistance rating
Android 7.0 Nougat
Ports on the bottom include a headphone jack, USB-C connector, microphone port, and speaker grille.
The front face is smooth and very nearly featureless—the physical home button has been replaced by a pressure sensor that lives under the display, making this a truly monolithic device.
Lastly, frequent SIM-swappers take note: there are two nigh-identical openings in the top of the S8+. One is for your SIM eject tool, and the other houses a microphone. Don't mix those up.
Time for a few quick comparisons before we get down to brass tacks.
In the three-fer, we've got the S7 Edge on the left, S8+ in the center, and S8 on the right.
Thanks to its thinner bezels and unusual 18.5:9 aspect ratio, the S8+ manages to pack a 6.2" display in about the same form factor as the 5.5" S7 Edge.
Stacked against last year's offerings, the only noteworthy difference is the migrating flash assembly and relocated fingerprint reader.
...But for all our talk, this rear panel does present something new. The fingerprint reader lives in the rear panel, with a very short cable tying it to the motherboard.
It looks like Samsung designed this cable to safely pull free with the rear panel. With almost no slack in the cable, the gentlest lift of the panel yanks the cable right out from its tiny pop connector. This makes it decidedly less damage-prone than certain fingerprint sensor cables we've seen before.
Cable dispatched, and we've got the glass out of the way. The S8+ and S8 follow the S6's move to a glass rear panel. This design has saved Samsung the engineering effort that goes into integrating antennas into a metal-backed phone, at the cost of durability and repairability.
Twice the crackability and a heck of an opening procedure won't help when it's time to score the repairability.
With the midframe coming out in pieces, things are looking very similar to the S7 and S7 Edge.
This time the upper antenna assembly is combined with the NFC/wireless charging panel, like on the Note7.
The coil should also perform Samsung Pay functions, duplicating MST—presumably using the coil as an electromagnet to act as a credit card strip would on a card reader.
Let's hope that Samsung's improved testing procedures are what the Note7 was missing, because this design looks about the same to us.
And it's still a bear to pry it off that adhesive. Even with the battery fully removed, the glue won't let go.
The S8+ features a 13.48 Wh (3500 mAh at 3.85 V) battery—the exact same capacity as the Note7, and a little less than the S7 Edge's 13.86 Wh.
Samsung continues to beat Apple in the battery capacity wars, with the iPhone 7+ weighing in at 11.1 Wh (2900 mAh at 3.82 V).
We pop out the action-packed motherboard and start plucking off cameras.
The "Hero" Sony of old has been traded in for the "Dream1" Sony in the rear-facing/main camera. Labeling variations aside though, this purports to be the same camera hardware as in the S7/S7 Edge—Samsung has refined the software, nothing more.
Next we have the front-facing camera and another iris scanning camera, previously seen in the Note7.
We push the cameras off to the side in order to pore over this motherboard's silicon. Our findings include:
Samsung K3UH5H50MM-NGCJ 4 GB LPDDR4 RAM layered over the MSM8998 Snapdragon 835
Toshiba THGAF4G9N4LBAIR 64 GB UFS (NAND flash + controller)
Qualcomm Aqstic WCD9341 audio codec
Skyworks SKY78160-11 front-end module w/ LNA
Avago AFEM-9066 front-end module
Qualcomm QET4100 envelope tracker
Silicon Mitus SM5720 Interface PMIC
And on the reverse side:
Qualcomm WTR5975 RF transceiver
Murata KM7118064 Wi-Fi module
Avago AFEM-9053 front-end module
Qualcomm PM8998 (similar to PMM8920) power management
NXP PN80T NFC controller w/ secure element
Renesas (formerly IDT) P9320S wireless charging receiver
Likely Knowles MEMS microphone
IC Identifications, pt. 2:
Qualcomm ? D5320 high-band diversity IC (likely)
Maxim Integrated MAX98506 audio amplifier
Qualcomm PM8005 ? power management
Maxim Integrated MAX77838 power management
Samsung S2MPB02 camera power management
Samsung S2MM005X02 USB power delivery controller (likely)
Samsung S5475S2 ? camera processor (likely)
IC Identifications, pt. 3:
NXP Semiconductor PCAL6524 24-bit I/O expander
ON Semiconductor FPF3688UCX load switch (likely)
ON Semiconductor FAN48630UC35X 1.5 A synchronous regulator
Vishay DG2730 2 port, 480 Mbps DPDT USB 2.0 analog switch
NXP Semiconductor NCX2200 comparator
ON Semiconductor FXLA0104QFX 4-bit voltage translator
Probably some low/mid-band front-end modules
IC Identifications, pt. 4 (sensors):
STMicroelectronics LSM6DSL 3-axis accelerometer/gyroscope (assumption)
STMicroelectronics LPS22HB Pressure Sensor
AKM Semiconductor AK09916C 3-axis electronic compass
Ablic (formerly Seiko Instruments) S-5712CCDL1-I4T1U Hall Effect Sensor (assumption)
Analog Devices ? Heart Rate Sensor
We extract the I/O daughterboard. There's lots of ingress proofing in evidence here, including the speaker grille surround and the tiny seals on the USB Type-C connector and headphone jack—all part of that IP68 rating.
The headphone jack itself remains a modular affair—good news for repairability, as this is a high-wear component.
This daughterboard also houses some antenna tuners and likely a Semtech SX9320 proximity sensor.
After a peek at the heat pipe and contact pad button cables, we extract a few more bits from the chassis.
Out comes ye olde vibrator motor.
Also the nifty sensor array (with moisture indicator):
RGB LED (probably)
IR emitter (for the iris scanning camera, maybe)
Likely AMS TMD4906 rangefinder/color sensor module (probably) for dimming the screen during calls.
On a hunt for the mysterious home not-button, we dig into the display despite previous... difficulties.
Luckily this fused display/digitizer peels up from its frame with a decent struggle, but no damage.
Hoping to find some hidden detail under the display cabling, we peel it up and find—zilch. No model info and no visible pressure sensor. Better luck next time.
Samsung S6E3HA6 display driver
STMicroelectronics fingertip touchscreen controller
Winbond W25Q80EWUXIE 8 Mb serial NOR flash memory
- Many components are modular and can be replaced independently.
- The battery can be replaced, but tough adhesive and a glued-on rear panel make it unnecessarily difficult.
- Front and back glass make for double the crackability, and strong adhesive on both makes it tough to access the internals for any repair.
- Because of the curved screen, replacing the front glass without destroying the display is extremely difficult.
まとめ
リペアビリティのスコア
(10点が最も修理しやすい指標です)
32 件のコメント
Hi: the breakdown exercise did you get a positive id on who is providing the USB-C controller chip? Thx!
I don't like glue on the battery and its not just that its the same capacity as we already see on the Samsung Galaxy S7 its kinda sad.
Man i now i will probably wait for one plus 5 or next google device because these two have big support on XDA community and they have regulari updates.
