はじめに
This is a Teardown of my old broken Samsung Galaxy Pocket (GT-S5300)
この分解は修理ガイドでは ありません。 お持ちのSamsung Galaxy Pocket (GT-S5300)を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Remove the battery cover Then remove the battery Then remove the battery
    • Remove the battery cover
    • Then remove the battery
  2. Remove all 4 screws Remove all 4 screws
    • Remove all 4 screws
  3. Slide a guitar pick between the sliver bezel and the rear of the phone Slide it all the way around until the rear is loosened from the logic board and screen
    • Slide a guitar pick between the sliver bezel and the rear of the phone
    • Slide it all the way around until the rear is loosened from the logic board and screen
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  5. Remove LCD connector Remove LCD connector
    • Remove LCD connector
  6. Remove logic board from screen by lifting  the logic board up and removing the digitizer connector
    • Remove logic board from screen by lifting the logic board up and removing the digitizer connector
  7. Remove the 5 screws to remove the shield Remove the 5 screws to remove the shield
    • Remove the 5 screws to remove the shield
  8. Remove what seems to be the antenna from the logic board Remove what seems to be the antenna from the logic board Remove what seems to be the antenna from the logic board
    • Remove what seems to be the antenna from the logic board
  9. Slide guitar pick between the digitizer and lcd Make sure not to get under the black adhesive on the back be the digitizer
    • Slide guitar pick between the digitizer and lcd
    • Make sure not to get under the black adhesive on the back be the digitizer
    • At the top of the digitizer there is a circuit be careful up there
  10. So that's my teardown for the Samsung galaxy pocket (GT-S5300)
    • So that's my teardown for the Samsung galaxy pocket (GT-S5300)
Ryan
メンバー登録日: 2014年02月08日
360 ポイント
1ガイドが承認済み
統計データを表示:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 45
今までの合計 10,840
