メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのSamsung GT-E2120を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Samsung GT-E2120 Teardown, Samsung GT-E2120 Teardown: 手順 1、 1の画像 1
    • Before you begin it's always good to ground yourself to eliminate the risk for shock.
  2. Samsung GT-E2120 Teardown: 手順 2、 2の画像 1 Samsung GT-E2120 Teardown: 手順 2、 2の画像 2
    • Using your thumb, press down on the back of the device in a downward motion to open the back cover.
    • Remove the battery along with the sim card and Micro-SD card.
    • This phone can take up to a 2GB Micro-SD card and is great for storing music. It even has a FM radio!
  3. Samsung GT-E2120 Teardown: 手順 3、 2の画像 1 Samsung GT-E2120 Teardown: 手順 3、 2の画像 2
    • Next, using a Philips screwdriver, remove the five screws from the back of the device.
  4. Samsung GT-E2120 Teardown: 手順 4、 3の画像 1 Samsung GT-E2120 Teardown: 手順 4、 3の画像 2 Samsung GT-E2120 Teardown: 手順 4、 3の画像 3
    • For this step a matal spudger is used to release the clips along the bottom, top, and sides of the phone.
    • These clips can be found at the points marked in red.
    • Working from the top down, gently prying at the case the clips are easily dislodged.
  5. Samsung GT-E2120 Teardown: 手順 5、 2の画像 1 Samsung GT-E2120 Teardown: 手順 5、 2の画像 2
    • When the bottom of the phone is reached it is a bit harder to pull the bottom clips off.
    • This can be made a tad easier by using the pointed end of the spudger to get in and under the case.
    • Once the case is lifted up slightly, you can get enough purchase under the clip and lift it off.
    • Be careful so you dont damage the motherboard!
  6. Samsung GT-E2120 Teardown: 手順 6、 1の画像 1
    • This images shows the two halves separated.
    • The camera located in the blue square is a VGA 640X480 resolution color camera.
  7. Samsung GT-E2120 Teardown: 手順 7、 2の画像 1 Samsung GT-E2120 Teardown: 手順 7、 2の画像 2
    • The microphone is carefully lifted from its bracket, and the motherboard is carefully removed.
  8. Samsung GT-E2120 Teardown: 手順 8、 1の画像 1
    • Then the keyboard is simply pushed out.
    • The Phone includes a 65K CSTN color screen with a 128X128 resolution.
作成者
3人の作成者と共同で作成されました。
Michael C
メンバー登録日: 01/09/11
410 ポイント
1ガイドが承認済み
チーム
OPEN OPEN人のメンバー
Community
82 メンバー
24のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 20
今までの合計 13,934
