メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのRubik's Cubeを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Rubik's Cube Teardown, Rubik's Cube Teardown: 手順 1、 3の画像 1 Rubik's Cube Teardown, Rubik's Cube Teardown: 手順 1、 3の画像 2 Rubik's Cube Teardown, Rubik's Cube Teardown: 手順 1、 3の画像 3
    • Turn the top row so that each corner is roughly halfway between the sides
    • Push the pieces up until they pop out of the cube, then, slide the rest out
    • Repeat this process until you clear the level
  2. Rubik's Cube Teardown: 手順 2、 2の画像 1 Rubik's Cube Teardown: 手順 2、 2の画像 2
    • You should be able to just directly pull out the rest of the blocks, like so
    • And there you have it!
    • You'll have the center piece, with the six centers of the six sides, the turning mechanism
  3. Rubik's Cube Teardown: 手順 3、 2の画像 1 Rubik's Cube Teardown: 手順 3、 2の画像 2
    • To reassemble, snap all the pieces back into place, and try not to rotate the faces.
    • It helps to start with the middle pieces first
    • Don't be afraid to use force!
    • Once you have the middle pieces in it's pretty simple to just push in the corner pieces
    • Again- don't be afraid to use force!
    Rubik’s Cube BROKEN using this method on a cube with a Circular Center. Last corner piece snapped when pushing in. Not recommended to use ‘force’ as the little plastic pieces can’t withstand it.
    * This method only works if you have a Rubik’s Cube that looks exactly like the one in the video when disassembled! If your Rubik’s Cube looks different (circular center) DO NOT USE THIS METHOD!!!!!
    Booya Tribe - 返信
作成者
1人の作成者と共同作成されました。
rab777hp
メンバー登録日: 11/17/09
20,333 ポイント
3のガイドは作成済み
チーム
OPEN OPEN人のメンバー
Community
82 メンバー
25のガイドは作成済み
6 件のコメント
I hated this thing. I disassembled mine with a .22 hollow point at 100 yards. Yes, It felt great!
mpias - 返信
lol don’t blame you, can’t stand the thing
Luke -
that method just broke my rubiks my cube.. thanks anyway
hamzamagdy888 - 返信
my middle peices came out cant fix it
jax - 返信
can someone tell me how to fix it
jax - 返信
grr i am mad that i cannot fix my rubik’s cube!
Devin Plante - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 26
今までの合計 24,543
