メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
この分解は修理ガイドでは ありません。 お持ちのRubik's Cubeを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Turn the top row so that each corner is roughly halfway between the sides Push the pieces up until they pop out of the cube, then, slide the rest out Repeat this process until you clear the level
    • Turn the top row so that each corner is roughly halfway between the sides
    • Push the pieces up until they pop out of the cube, then, slide the rest out
    • Repeat this process until you clear the level
  2. You should be able to just directly pull out the rest of the blocks, like so And there you have it!
    • You should be able to just directly pull out the rest of the blocks, like so
    • And there you have it!
    • You'll have the center piece, with the six centers of the six sides, the turning mechanism
  3. To reassemble, snap all the pieces back into place, and try not to rotate the faces. It helps to start with the middle pieces first
    • To reassemble, snap all the pieces back into place, and try not to rotate the faces.
    • It helps to start with the middle pieces first
    • Don't be afraid to use force!
    • Once you have the middle pieces in it's pretty simple to just push in the corner pieces
    • Again- don't be afraid to use force!
rab777hp
メンバー登録日: 2009年11月17日
21,279 ポイント
3のガイドは作成済み
チーム
OPEN OPEN人のメンバー
Community
77 メンバー
17のガイドは作成済み
6 件のコメント
I hated this thing. I disassembled mine with a .22 hollow point at 100 yards. Yes, It felt great!
mpias - 返信
lol don’t blame you, can’t stand the thing
Luke -
that method just broke my rubiks my cube.. thanks anyway
hamzamagdy888 - 返信
my middle peices came out cant fix it
jax - 返信
can someone tell me how to fix it
jax - 返信
コメントを追加
統計データを表示:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 56
今までの合計 21,868
