メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのRevlon 1875W Compact Travel Hair Dryer を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Revlon 1875W Compact Travel Hair Dryer  Teardown, Revlon 1875W Compact Travel Hair Dryer  Teardown: 手順 1、 3の画像 1 Revlon 1875W Compact Travel Hair Dryer  Teardown, Revlon 1875W Compact Travel Hair Dryer  Teardown: 手順 1、 3の画像 2 Revlon 1875W Compact Travel Hair Dryer  Teardown, Revlon 1875W Compact Travel Hair Dryer  Teardown: 手順 1、 3の画像 3
    • Before disassembly, make sure that the device is unplugged.
    • Remove the back fan grill from the case.
    • Unscrew the two PH2 black screws located on the back of the handle .
  2. Revlon 1875W Compact Travel Hair Dryer  Teardown: 手順 2、 2の画像 1 Revlon 1875W Compact Travel Hair Dryer  Teardown: 手順 2、 2の画像 2
    • Separate the back and front case.
    • As you remove these you will find there is snap fit finger holding the case at the top.
  3. Revlon 1875W Compact Travel Hair Dryer  Teardown: 手順 3、 2の画像 1 Revlon 1875W Compact Travel Hair Dryer  Teardown: 手順 3、 2の画像 2
    • Fan speed, cold shot buttons, and rest of electronic components are nested in the handle section of the front case . These connect to the fan and heating coils in the shoot.
    • Cold shot button uses a TOPLY YSS-16 slide switch
    • High-Off-Low button is a 3 position slide switch.TOPLY YSS-16-2413.
  4. Revlon 1875W Compact Travel Hair Dryer  Teardown: 手順 4、 1の画像 1
    • At this point you can pull the complete electronic sub assembly from the front case.
  5. Revlon 1875W Compact Travel Hair Dryer  Teardown: 手順 5、 1の画像 1
    • Motor and open coils are closely soldered. There are 2 coils that control the temperature
    • Motor is yfd 385 2073 57
  6. Revlon 1875W Compact Travel Hair Dryer  Teardown: 手順 6、 2の画像 1 Revlon 1875W Compact Travel Hair Dryer  Teardown: 手順 6、 2の画像 2
    • 7 Fin PP impeller. This is tightly glued to the motor's shaft.
    • Uses a Hair Dryer Fan DC Motor yfd 385 2073 57
    • The fan and motor are tightly integrated, making it impossible to replace the fan without destroying it.
作成者
3人の作成者と共同で作成されました。
Stephanie Lopez
メンバー登録日: 02/19/18
133 ポイント
1ガイドが承認済み
2 件のコメント
Great share ! Thanks for the information in electronic sub assembly,You can find more details by visiting our site
http://www.mexcontrol.com/
Pradeep p - 返信
I'm having trouble getting mine back together! Is there a more detailed guide?
Jack B - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 18
過去 30 日: 122
今までの合計 5,520
