メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのTweezersを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Reversed tweezers Teardown, Reversed tweezers Teardown: 手順 1、 3の画像 1 Reversed tweezers Teardown, Reversed tweezers Teardown: 手順 1、 3の画像 2 Reversed tweezers Teardown, Reversed tweezers Teardown: 手順 1、 3の画像 3
    • This my friends, is the first ever iFixit-made-tool teardown on iFixit
    • Stainless steel body and nylon tips, with the iFixit logo printed on it...
    • Reversed so you can hold tiny Lego hats even when your hands are busy...
  2. Reversed tweezers Teardown: 手順 2、 3の画像 1 Reversed tweezers Teardown: 手順 2、 3の画像 2 Reversed tweezers Teardown: 手順 2、 3の画像 3
    • Time to tear it down!
    • Its not often that regular Philips screws are used on modern devices!
    • So far we've been able to take off a lot of the tool's construction using Only a PH0 screwdriver!
    • Have dreams come true?
    • We Remove the Last parts anddddd...
  3. Reversed tweezers Teardown, Final Thoughts: 手順 3、 1の画像 1
    この手順で使用する道具:
    Nylon Tipped Tweezers
    $2.99
    購入する
    What is the pitch between the screw holes?
    Colton - 返信
    Also, do you know what the thickness of the tips are and the length of the screws?
    Colton - 返信
作成者
2人の作成者と共同で作成されました。
Aiden
メンバー登録日: 09/19/15
17,486 ポイント
21のガイドは作成済み
8 件のコメント
Where can you find the replacement parts?
echow2001 - 返信
Repairability: 11 out of 10.
Jake Rose - 返信
lol i actually needed this to fix mine
Luke - 返信
Very glad to know replacement tips are sold! I had no idea these were nylon until I melted the ends. Whoops!
The Purple Ender Eye - 返信
If you have the order number of the original or a photo of the kit it came with, theyll replace it for free if you use their email support.
Tito_deTrapio94 -
So I have to purchase the Nylon Tipped Tweezers to get a set of Nylon Tips to replace my Reverse Tweezers Nylon Tips? Can't jus buy the tips?
Randy
Clarence Hayes - 返信
You can definitely get the tips only. And they are covered by the lifetime warranty. Just contact their email support. they sent me 2 replacement packs for free.
Tito_deTrapio94 -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 19
過去 30 日: 64
今までの合計 3,541
