はじめに
Quarantine turned you into a gamer? Lucky for you, Razer’s new Kishi Universal Controller is here to turn your smartphone into a play-anywhere system, with real buttons and joysticks. Join us as we tear down this stretchy controller to take a closer look at its inner workings and evaluate its repairability.
Want more exciting news and teardowns? Follow us on Twitter, Instagram, and Facebook, or sign up for our newsletter.
必要な工具と部品
Let's see what the Razer Kishi brings to the smartphone gaming ... game.
Standard A-B-X-Y buttons, two clickable analog thumbsticks, one 8-way D-pad, plus a shoulder button and a trigger button on each side)
Direct connectivity to your phone via USB-C or Lightning connector (depending on which model you buy)
No internal battery, no Bluetooth, and no headphone jack
Compatible with Android 8 Oreo/iOS 9 or higher, supporting device dimensions of 145.3–163.7mm (H), 68.2–78.1mm (W), and 7.0–8.8mm (D)
この手順で使用する道具:Mako Driver Kit - 64 Precision Bits$39.95
Game time started—we blast off ten Tri-point screws from the rear side. Thankfully we came equipped with 64 bits of Mako Driver Kit goodness. We're leveling up already!
Beneath the back cover, we find two Steam-ish booby-trap interconnect cables—each one snaking off to a separate circuit board.
Instead of the tricky Tri-points found in other portable gaming options, we find regular Phillips #0 screws inside of the handles.
Normally each new level gets more challenging, but here it seems Razer gave us a break. Or is it just a distracting side quest? Regardless, we're happy to go on a Phillips fetch quest.
There's no boss battle here yet—just a couple boards, which we quickly extract.
The right board contains the following bijous:
Fresco Logic FL7102, USB3.1 Type-C PD3.0 Controller
Soldered-on USB Type-C charging port
Soldered-on joystick controller (hello Oculus Touch and Xbox One S)
Plug-in phone connector (in this model USB-C)
Soldered-on breakout board for one of the shoulder buttons
"Forward" button
Indicator LED
On the back of the board we discover:
Broadcom (formerly SiByte) 4407 DA9N1S microprocessor
A breakout board for the second shoulder trigger, which is attached separately and is therefore easier to repair.
This one seems to use some sort of rotary knob offering not only an on/off status but a gradual push depth of the shoulder trigger.
What remains is the telescoping slider mechanism that supports your phone when attached to the Kishi.
It includes a folding rubber cushion, which attaches to the back cover with small springs. That's what saves you from worrying about scratches on the back of your phone while gaming.
- No adhesive was used and components are attached with screws.
- The controller's relatively modular construction means replacing most components will be a simple task.
- One of the most strained parts—the phone connector—is plug-in and easy to replace.
- We always say screw before glue. But using two different types of screws—one of them being Tri-point—is unnecessary and a bit annoying.
- The most likely-to-fail components—both joysticks—are soldered directly onto the circuit boards, as is the passthrough USB-C charging port.
まとめ
リペアビリティのスコア
(10点が最も修理しやすい指標です)
25 件のコメント
Very useful. I wonder if there's any unused traces on the ribbon cable: thinking of adding stereo speakers using a small Bluetooth module (though it seems rather packed).
That’d be nice tinkering. Please share if you find anything.
Huuu miy buena idea amigo compartirias el proyecto??? Para intentarlo serianear con sonido estereo
I’m still wondering why Razer didn’t include support for USB-C headphones. Looking at the internals makes me wonder if it was more work to make it charge-only.
I wonder if those analog stick caps can be swapped for the ones from an actual Xbox One controller? I bet that would be an upgrade.
Please share if you tried that swap. I bet others wonder about that too.
Any Luck with this swap? The rubbers have peeled off my sticks and Im looking for a replacement... just happen to have a few xbox sticks lying around from previous upgrades.
Unfortunately we don’t have spare parts for that controller. Hope you’ll get lucky on the interwebs.
My kishi failed on me after 4 months. I can assess it was the passthru usb-c charging that caused it's demise. I noticed it was hot and unplugged it not being worried. Hours later I reconnected it with no input to be found. I'll probably never repair it but I enjoyed this teardown none the less…
Whats the white stuff on the spring of the trigger buttons?
That white stuff is just some lubricant to make the triggers go swoooosh ;) (and not get jammed on its plastic guide rail)
My communication flex has failed, where can I get a replacement? Or what are the characteristics of the flex?
well, I found the ideal flex for this game on AliExpress, it is 14 pins, with a difference of 0.5 millimeters between them and the direction of advance.
Whats the dimensions of the analog? I wanna replace it with 3D flat analog, i really dont like the sticks ……
Hi @Cameei, we think it is the ThumbPointer stick with serial number RKJXV. Here is the matching data sheet: https://www.mouser.de/datasheet/2/15/RKJ.... Have fun with the replacement!
Do you happen to know which pins are broken out on phone connector?
You know what would be cool? If you make a tutorial of how to swap the usb C type port with a lightning port.
In that way, the ones that have to change from device like android to iphone and vice versa can easily do it without having to buy a new Kishi, and save some budget.
You mean this guide here ;)
Yo compre uno de esos y a los dias dejo de funcionar un lado se podra arreglar. me imajino que talves el flex, pero no creo que vendan repuestos. alguien me podria ayudar o desirme como podria arreglarlo por favor
En caso de que se caliente o no se pueda cargar el teléfono a través del control se debe a que el chip Fresco Logic FL7102 se haya quemado y eso este causando la falla, en lo personal se puede seguir usando el control, pero no se podrá cargar el teléfono a través de él, las temperaturas serán incomodas al tacto y después de un tiempo dejara de funcionar.
Desconozco si existen repuestos para ese chip en específico.
Hi Felipe, thanks for your comment. Unfortunately, we don’t have a source for replacement parts.
But I’ll paste an English translation of your comment for others, maybe somebody knows something and can help out.
In the event that the phone gets hot or cannot be charged through the control, it is because the Fresco Logic FL7102 chip has burned out and that is causing the failure, personally you can continue using the control, but you will not be able to charge the phone through it, the temperatures will be uncomfortable to the touch and after a while it will stop working.
I don't know if there are spare parts for that specific chip.
Is the left side glued? I can't separate the left side, as it is sealed shut like it was glued together.
