メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのPsion 5を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Psion 5 Teardown, Psion 5 Teardown: 手順 1、 1の画像 1
    • A Psion Series 5!
    • On screen, it has a permanent taskbar. 8MB internal store. A big keyboard. And you can record while the Psion is closed with external buttons.
  2. Psion 5 Teardown: 手順 2、 1の画像 1
    • Let's turn it!
    • There's a Compactflash card. You can use it for backups or documents.
    • Remove the three screws, holding the backcase.
    • There was a "guarantee void if removed" sticker. Anyway, this device is over 12 years old, there's no guarantee!
  3. Psion 5 Teardown: 手順 3、 3の画像 1 Psion 5 Teardown: 手順 3、 3の画像 2 Psion 5 Teardown: 手順 3、 3の画像 3
    • Open it from the back to the front.
    • Don't forget to remove the plastic on the back.
    • Now let's see what we found:
    • EPOC with the OS stored in ROM. It's removable for the different languages & countries.(Chip with the green stick on it.) The other one is the 4MB RAM.
    • ARM 710 RISC-processor with 18.43MHz.
    • The touchscreen controller.
  4. Psion 5 Teardown: 手順 4、 3の画像 1 Psion 5 Teardown: 手順 4、 3の画像 2 Psion 5 Teardown: 手順 4、 3の画像 3
    • Remove the three screws, holding the mainboard in place.
    • Don't remove the mainboard, there are some ribbon cables.
    • Remove the two ribbon cables, one on the left, the other one on the right side.
    • Used for power and speaker.
    • Used for powering the backlight.
  5. Psion 5 Teardown: 手順 5、 3の画像 1 Psion 5 Teardown: 手順 5、 3の画像 2 Psion 5 Teardown: 手順 5、 3の画像 3
    • Now, slide up the Psion.
    • Carefully remove the mainboard and diconnect the two ribbon cables. (That's the faulty design I mentioned in the description.)
    • Let's see the other side of the mainboard:
    • 4x 2MB of RAM.
    • Connectors for the two ribbon cables. The blu one's the keyboard and the brown one's screen and touchscreen cable.
    • Compactflash card connector.
    • Connector for PC synchronistation,Printer and internet.
    • Again, the front of the mainboard.
  6. Psion 5 Teardown: 手順 6、 3の画像 1 Psion 5 Teardown: 手順 6、 3の画像 2 Psion 5 Teardown: 手順 6、 3の画像 3
    • That's the trickiest part in the whole disassembly.
    • First, remove the spring hinge.
    • Unhook them on both sides. Careful not to snap any of the ABS casing!
  7. Psion 5 Teardown: 手順 7、 3の画像 1 Psion 5 Teardown: 手順 7、 3の画像 2 Psion 5 Teardown: 手順 7、 3の画像 3
    • Slide the screen from the chassis.
    • Use a knife to slide out the metal peg holding the keyboard to the screen on each side.
  8. Psion 5 Teardown: 手順 8、 2の画像 1 Psion 5 Teardown: 手順 8、 2の画像 2
    • Remove the keyboard.
    • A total of 12MB internal. Made in UK 1997.
  9. Psion 5 Teardown: 手順 9、 2の画像 1 Psion 5 Teardown: 手順 9、 2の画像 2
    • You can pull out the screen from the plastic case.
    • That's the backlight. It shines very green, so instead of black/wihte you had grey/green. Today, you would install some LEDs and that's it.
  10. Psion 5 Teardown: 手順 10、 3の画像 1 Psion 5 Teardown: 手順 10、 3の画像 2 Psion 5 Teardown: 手順 10、 3の画像 3
    • Thats the screen.
    • You can see, the screen is made of two parts:
    • That's the touchscreen.
    • That's the greyscale LCD screen from Sharp.
  11. Psion 5 Teardown: 手順 11、 1の画像 1
    • Everything laid out:
    • Plastig case.
    • LCD screen and touchscreen.
    • Backlight.
    • Chassis with speaker.
    • Mainboard.
    • Keyboard (German layout)
    • Thank you for reading & watching my Teardown :)
作成者
1人の作成者と共同作成されました。
Peddy
メンバー登録日: 12/28/09
159 ポイント
2のガイドは作成済み
3 件のコメント
For more Psionrepairs: Mail: psion@hccnet.nl (december 2010)
Dirk van Schravendijk - 返信
Does there exist a description of the keyboard connector? I have a fully operational Psion 5 but its screen is cracked from top to bottom. Only the left side of the screen is now sensitive to touch. The whole screen shows data so that functions properly. Now I'd like to use the screen with my Rasberry Pi 2. Won't tear it down just yet. Thanks.
Cor Massar -
Dears, Did You have a pinout for serial rs232, for Psion MC218 ?
Thanks!
goran.krstic@lanaco.com
Goran - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 60
今までの合計 21,185
