はじめに
The digitizer is glued to the screen and heat gun is recommended to separate the two parts properly.
必要な工具と部品
Insert the plastic opening tool into the groove between the two halves of the cover. Pry the two halves apart working your way around the perimeter of the case.
Using a heat gun, apply heat to the front of the screen for 3-5 minutes to release the glue.
Using a plastic opening tool, pull back on the plastic blue tabs to release the digitizer and pry it back from the screen.
Remove the black trim the lines perimeter of the screen and is attached to the digitizer.
