必要な工具と部品
Obtain your plasma ball and unplug the wire (If battery operated take out battery's).
Turn the Off/On/Sound switch to Off.
Flip over the plasma ball ( Be careful if putting on a table, its glass its easily broken)
Unscrew the 4 screws, one in each corner of the mechanism.
Carefully pull apart the base from the main body,
Now we have the base and the main panel.
Unscrew the two screws that hold the base to the control center.
Next pop out the control center by pushing on these two plastic holders.
Pull the control center off the base and you are done with the teardown
To rebuild the Plasma Ball do all the steps in reverse order.
18 件のコメント
Interesting teardown! Although, it might be noted that care should be taken when handling the circuit board, especially around the flyback transformer (big black cylinder), as plasma balls typically operate on high voltages and may pose a shock hazard.
does anyone know anything about troubleshooting electrical issues? I have a ball this is 20 years old and worked in 2016 when i packed it to move, but when i reopened it 8 months later i get nothing when i turn it on. Anyone have ideas?
It could be a couple things leading to this. The wire could be faulty or the wire is not touching the steel wool are most likely the problem. You could try and tear down adjust it and see if it helps.
When I tried putting it back together it would not light the same way does anyone know how to fix this?
Cmolinar98 - 返信
Need to ensure the wire touches the steel wool when reassembling.
Thanks! Used to repair the plasma ball at local children's museum.
A high-voltage discharge from a Van De Graaff generator to the plasma ball globe killed the latter. What internal component is most likely damaged?
I had one forabout 30 years.. sometimes people would put metal objects up to the glass 4 bigger spark effect. and then one day it just didn't work like it used to. after some fine scrutinizing I realized that the metal objects being held up to the glass creating amuch stronger Arkinside that the ark actually burned a tiny pinhole through the glass bulb no vacuum no spark. was able to pull a vacuum on the tube seal the hole and Wallah she worked again only to be burned up in house fireyears later
I totaly tore down illumina storm and cleaned and adjusted wool and wire im getting power to the point to where it plugs into slide bottons but wont even flicker when turned on NEED SOME HELP HERE???
I need to but what happens if it electrocutes me
Where can i get the replacement coils?
What Plasma Ball is this specifically? Like the brand name of it
Is a plasma ball meant to be left on for a few hours or more? I bought one at a Yardsale today and it worked great, but I accidentally left it on and about 5 hours later I noticed it was warm and no longer working. Any ideas or suggestions?
