はじめに
In this guide you will see the Palm Treo Pro fully torn down into its individual parts.
必要な工具と部品
Use the Torx T5 screwdriver to remove the 5 visible 6mm screws on the back of the phone.
Use the plastic opening tool to pry the side of the display glass up so you can easily remove it with your hand.
Locate the four tabs above the keyboard. The following steps will demonstrate how to remove the metal plate from the tabs, which will reveal the keyboard.
