メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのEasyNote TK87-JO-050PLを修理する際は、iFixitの修理ガイドをご利用ください。
    • Unplug your device and take out the battery
    • Avoid leaving the battery in unless you want to get shocked
    • Slide the locked switch to the unlock position.
    • Unscrew all screws on the main body. NOT IN THE BATTERY COMPARTMENT
    • Keep the screws in a small bag or container with separate compartments for reassembly
    • Remove the screws from the HDD and RAM compartment
    • Then remove the cover for the compartment, and use a pry tool if necessary
  1. Packard Bell EasyNote TK87-JO-050PL Teardown, WIFI Module: 手順 4、 1の画像 1
    この手順で使用する道具:
    • Use some tweezers to remove both the black and white cable connecting to the wifi module, and wiggle them back and forth if needed. The cables connect upwards so don't move them towards the sides only rotate if wiggling
    • Don't use excessive force, they should just slide out.
    • To finish with the wifi module just unscrew the 1 screw located on the module, then pull it out.
    • If you can't get it out, then leave it in it shouldn't get in our way
    • Remove all screws in the HDD&RAM compartment and all screws in the battery compartment
    • Don't touch the screws on the HDD itself
  2. Packard Bell EasyNote TK87-JO-050PL Teardown, Removing the keyboard: 手順 6、 1の画像 1
    • There are little clips peppered along to top of the keyboard push them in then use a pry tool to keep the keyboard up.
    • Lift up the keyboard and disconnect the ribbon cable
    • And, TaDa! You removed the keyboard and got so far into this teardown, there's not a lot to go so keep going!
  3. Packard Bell EasyNote TK87-JO-050PL Teardown, Removing the top main body: 手順 7、 3の画像 1 Packard Bell EasyNote TK87-JO-050PL Teardown, Removing the top main body: 手順 7、 3の画像 2 Packard Bell EasyNote TK87-JO-050PL Teardown, Removing the top main body: 手順 7、 3の画像 3
    • Remove all screws labelled "5L" and keep them seperate
    • Use a pry tool along the edges to remove the top main body
    • Make sure to disconnect the ribbon cables and connector shown
作成者
2人の作成者と共同で作成されました。
Ethernal Alchemist
メンバー登録日: 05/16/22
242 ポイント
1ガイドが承認済み
4件のガイドコメント
Not doing to help me
Can you help by another system
Star Tesfamikael - 返信
Battery not charging
Edivier Mna - 返信
My Computer's Battery is not charging.
When I use other changer, it's working on
Edivier Mna - 返信
Mon ordinateur ne s'allume plus
Mbayediaye Diallo - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 51
今までの合計 584
