メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのOsram Lightifyを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Osram Lightify Teardown, Osram Lightify Teardown: 手順 1、 1の画像 1
    • This is the Osram Lightify. This is a broken unit that does not sync to the app properly. I got a free replacement due to that.
    • Ooh... Shiny! you can see my iPhone 5s in it!
    • No more chit-chat. Time to dig in!
  2. Osram Lightify Teardown: 手順 2、 2の画像 1 Osram Lightify Teardown: 手順 2、 2の画像 2
    • A mysterious unlabeled button. sadly, not red.
    • The info for the device, Zigbee certified. Zigbee tries to turn all the different wireless control apps and stuff into one app.
    • It almost seems like someone taped over the device's unique ID to control it...
  3. Osram Lightify Teardown: 手順 4、 3の画像 1 Osram Lightify Teardown: 手順 4、 3の画像 2 Osram Lightify Teardown: 手順 4、 3の画像 3
    • Hmmm... No give. maybe not that side.
    • When it goes back in, it gives a nice deafening POP.
    • Finally. now we are getting somewhere.
  4. Osram Lightify Teardown: 手順 5、 3の画像 1 Osram Lightify Teardown: 手順 5、 3の画像 2 Osram Lightify Teardown: 手順 5、 3の画像 3
    • The white thing seems to let light through, but not let you see through to the inside.
    • Seems to just pop right off. This is pretty easy so far!
    • You can now see right through it.
  5. Osram Lightify Teardown: 手順 6、 2の画像 1 Osram Lightify Teardown: 手順 6、 2の画像 2
    • Its now open!
    • With no option in sight, we keep on prying.
  6. Osram Lightify Teardown: 手順 7、 3の画像 1 Osram Lightify Teardown: 手順 7、 3の画像 2 Osram Lightify Teardown: 手順 7、 3の画像 3
    • Not much to see here...
    • These Appear to be antennas...
    • The only interesting thing so far: Some flash memory, at a whopping 32 megabits the spiflash 25Q32FVSIG . Wow.
    • There has to be something under these plates...
    • Prying was no help. these plates seem to be mounted with... SOLDER
    • Commence desoldering.
  7. Osram Lightify Teardown: 手順 9、 1の画像 1
    • After a good amount of prying and a small nick on my thumb, We get back to work.
    • Time for some chip identification!
    • This one appears to be WLAN SoC. its a Marvell 88W8782.
    • The brains of it all, the Micro controller. A Marvell 88MC200
    • And on the smaller side, (what I think is) a Zigbee gateway. a Marvell MZ100
    • Lets dig deeper!
  8. Osram Lightify Teardown: 手順 10、 3の画像 1 Osram Lightify Teardown: 手順 10、 3の画像 2 Osram Lightify Teardown: 手順 10、 3の画像 3
    • Oh goodie! the first screws!
    • there are 2 Torx T9 screws holding in what looks like the power supply.
    • yep, that's the power supply.
  9. Osram Lightify Teardown: 手順 11、 3の画像 1 Osram Lightify Teardown: 手順 11、 3の画像 2 Osram Lightify Teardown: 手順 11、 3の画像 3
    • The prongs that plug into the wall, are not actually soldered to the board, but are just connected by contacting. interesting...
    • There are 2 more Torx T9 screws holding in the cover. most likely after removal of the cover the prongs can also be removed.
    • The 4 screws are all the same, so you can mix and match to your heart's desire!
    • Nope, not individually removable.
  10. Osram Lightify Teardown: 手順 12、 1の画像 1
    • I actually highly advise against doing this.
  11. Osram Lightify Teardown: 手順 13、 3の画像 1 Osram Lightify Teardown: 手順 13、 3の画像 2 Osram Lightify Teardown: 手順 13、 3の画像 3
    • On the back we have two long metal sheets.
    • Removal is pretty straightforward.
    • And on the front again, the button slides right out.
  12. Osram Lightify Teardown: 手順 14、 1の画像 1
    • I'd give this a 9 out of 10.
    • All screws and tabs.
    • Easily repaired without much knowledge of repair.
    • main board slides right out of the power connections.
    • Tiny bit of adhesive on the logo holding it in place, so it will not securely fit in after removal. although it will still fit snugly and not come out without rough handling. This is an unlikely repair anyway.
作成者
1人の作成者と共同作成されました。
Aiden
メンバー登録日: 09/19/15
17,429 ポイント
21のガイドは作成済み
3 件のコメント
@oldturkey03 I’ve always knew my soldering skills ;)
Aiden - 返信
@captainsnowball Looks good. Now, all you have left to do is to tell the world what is under the EMI shields.
oldturkey03 - 返信
will do tommorow
Aiden -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 3,084
