はじめに
OnePlus adds another one to their incrementally-expanding, arithmetic-themed line of smartphones. The OnePlus 6 looks pretty good on paper, but how will these fancy specs add up on the teardown table? Join us as we do a little repair-themed math of our own.
Looking for more teardown action? Following us on Facebook + Instagram + Twitter = easy access to all our teardowns.
必要な工具と部品
ビデオの概要
OnePlus is known for adding up a lot of flagship-phone features while subtracting the flagship-phone price, and the 6's specs don't disappoint:
6.28” Samsung-made AMOLED display with 2280 x 1080 resolution (402 ppi) and 2.5D Gorilla Glass 5
Octa-core, 64-bit Qualcomm Snapdragon 845 processor with 6 GB or 8 GB LPDDR4X RAM
Dual main camera with 16 MP (ƒ/1.7 with OIS) and 20 MP (ƒ/1.7) modules; 16 MP (ƒ/2.0) selfie camera
64 GB, 128 GB, or 256 GB built-in storage
USB Type-C and 3.5 mm audio ports
OxygenOS based on Android Oreo 8.1
Around back we have a camera bump that looks a tad Apple-like, paired with a fingerprint sensor in a layout and location reminiscent of other Android flagships.
NFC in the camera you say? Thanks for the tip—we'll keep an eye out for that during the following "unauthorized disassembly."
On the bottom: headphone jack (yay!) and USB Type-C.
No need to go in blind when you have X-ray vision—our friends at Creative Electron give us an overview of this smartphone's terrain.
Everything looks pretty standard—except for the huge sliding mechanism for the alert slider! If we didn't know any better we'd have guessed it was some kind of linear actuator.
Satisfied with our virtual foray into the phone, we turn to the SIM card tray and find the first evidence of the OnePlus 6's rumored water resistance—an integrated rubber gasket.
Android phone with a glass back? Gone is the classic OnePlus metal casing! But we've seen this before...
...and we have a well-tested solution. The heat gun softens things up and the iSclack and opening pick take care of the rest.
We lift the back in trepidation, waiting for the familiar tug of a fingerprint sensor cable.
But we're pleasantly surprised—the OnePlus 6 comes with a cable long enough to completely remove the back without worrying about tearing the cable.
We pop off a nice red bracket to free that lengthy fingerprint sensor cable, and spy the NFC antenna OnePlus so graciously pointed out.
The friendly green tab on this relatively accessible battery says, "由此拉起可拆出电池". This translates to "Pull up and out to remove the battery."
Despite inconsistent labeling, this battery should be consistently easy to remove with that pull tab—it's only lightly adhered in place. Here OnePlus decidedly one-ups its competition.
However, the battery falls behind its peers in capacity, with 12.70 Wh—slightly under the Galaxy S9+ (13.48 Wh) and Google Pixel 2 XL (13.6 Wh).
Nine Phillips screws bite the dust and the plastic antenna frame doesn't budge. But a secret tenth screw behind a liquid damage indicator grants access.
Under the plastic midframe, we get up-close and personal with that oversized slider mechanism.
The slider button moves a hefty metal plunger, which flips a mechanical switch soldered to the motherboard. The X-ray image provides an even better view.
The switch design is a result of the small (narrow) switch needing to move a slider with very distinct detente points. Moving that plunger keeps the switch moving more linearly (more of a push/pull, as opposed to a lever-action, which puts angular stress) and ensures easier finding/stopping the middle position. Very clever design.
Now that we have an entirely logical answer, here’s a decidedly more illogical but fun possibility:
I’m going to go with a more off-the-wall and Goldberg-ian idea - the metal plunger is designed to be used with a docking station with a moveable magnet to simultaneously help align the phone for wireless charging and also allow the docking station to move the alert switch in response to a pre-programmed user schedule. Entirely unnecessary and far from pragmatic but, woah! Right?!
Having removed all the connectors tethering the motherboard to the phone, we slide it free and take a look at what chips it holds:
Samsung K3UH7H70MM-AGCJ 8 GB LPDDR4X DRAM (layered over Qualcomm Snapdragon 845)
Samsung KLUDG4U1EA-B0C1 128 GB embedded universal flash storage
Qualcomm WCD9341 Aqstic Audio Codec
Qualcomm QDM3620, QDM3670, QDM3671 Diversity Receive Modules
NXP Q3303 NFC Controller
Qualcomm PMI8998 PMIC
Maxim Integrated MAX98928 audio amplifier
Can i get this part replaced?
Can I replace my 64gb memory chip with 128gb?
Is it practical?
Next we flip the board and check out the rest of its chips:
Qualcomm WCN3990 2x2 802.11ac Wi-Fi with MU-MIMO companion
Qualcomm SDR845 RF transceiver
Qualcomm PM8005 PMIC
Qualcomm PM845 power management
Skyworks SKY78160-11 WLAN power amplification module
AVAGO AFEM-9046 front end module
AVAGO AFEM-9036 front end module
IC Identification, pt. 2:
Skyworks SKY85814-11 WiFi dual-band 802.11ac front-end module
Qualcomm QET4100 envelope tracker
STMicroelectronics STM8S003F3 8-bit Microcontroller w/ 8 Kb flash
Bosch Sensortec BMI160 3-axis accelerometer/gyroscope
Texas Instruments TPS65633B AMOLED display power supply
Texas Instruments TXS0104E 4-bit bidirectional voltage-level translator
Knowles MEMS microphone
IC Identification, pt. 3:
Maxim Integrated MAX14743 dual SPDT analog switch
ON Semiconductor FSUSB42UMX and NL3S2223 2-port 480 Mbps USB 2.0 analog switch
ON Semiconductor FPF2280 OVP load switch
Texas Instruments LP5907SNX-2.8 250 mA LDO regulator
ON Semiconductor NCP114AMX300TCG and NCP114AMX180TxG 150 mA LDO regulator
ON Semiconductor NCP140AMXD330TCG 300 mA LDO regulator
ON Semiconductor DC-DC Converter
Before we leave the board, let's talk waterproofing. We found some! There are black silicone seals surrounding all these flex cable sockets—as we found previously on the OnePlus 5, and just like on every iPhone since the 6s.
Moving down to the other end, under the single loudspeaker assembly, we find more gaskets surrounding the speaker grille, USB Type-C port, and nicely modular headphone jack.
That’s funny. I decided to give the pool jumping a try, OP6 in my pocket for about 1 minute. Screen died :(
Let's circle back and talk cameras for a moment.
Alongside it resides the 20 MP Sony IMX 376K sensor, returning from the earlier OnePlus 5T. The selfie cam gets the 16 MP IMX 371, which has been in circulation since the OnePlus 5 days.
Returning to the bottom edge, we flip out this little daughterboard and survey what's left in the chassis.
That OLED panel is firmly glued in place—it probably won't come out undamaged. You'll likely only be removing a broken display of course, but the procedure for doing so sure isn't repair-friendly.
Slightly incorrect as this isn't the first OnePlus to have OIS. The OnePlus 3 and 3T had it as well.
Thanks for the correction, I updated the step to reflect that.
I’m surprised how you go on to make a universal claim about the camera saying “reviews have found it to be lackluster versus the competition”, with the “review” from theverge as your only source, when this definitely isn’t the general consensus across the review-sphere.
@mtaki14 Fair point! Amended to say early reviews have been mixed, with links to several reviewers who feel the OnePlus 6 camera compares favorably with the Pixel 2 and iPhone X.
That's a wrap! If we had one word to describe the sheer number of pieces we pulled from this phone, it would be twelve.
While we're on the subject of hard numbers, let's give this phone a repairability score.
I having oneplus 6 8GB + 128GB variant and I need main mother board for it, my phone keep on restarting and the WiFi is not connecting.. any suggestions pls
- The battery can be accessed almost the moment you open the phone, and is only lightly adhered in place. Plus, there's a convenient pull tab.
- Many components are modular and can be individually replaced.
- All the threaded fasteners are of the standard Phillips variety.
- Display replacement, the most common repair, is not prioritized in the design and will take a lot of work.
- Front and back glass means twice the risk of cracks—without even the benefit of wireless charging.
- The primary access point for all repairs is heavily glued in place.
まとめ
リペアビリティのスコア
(10点が最も修理しやすい指標です)
20 件のコメント
I can’t fully grasp what that huge plunger is doing, even with your description and images. I’m 100% confused
I’d guess it’s there for better alignment. The detent on the 3T that I have works well, but there is some play introduced because the slider can roll slightly on the head of the switch, giving it some slop.
Is the vibrator a linear system or a rotating one? I remember seeing a casing similar to this one on the S6 and S7 (which gave strong, quiet vibration) but it could just be a circular rotating assembly like on the original Nexus 5 (which was honestly horrible.) I’m hoping it’s the former, as that would be a significant upgrade over the standard barrel motor vibrator on previous Oneplus phones.
The vibrating motor looks like a rotating one from the pictures above (Step 11 picture).
So there is no heat sink or heat pipe here as we see these days with those Samsung flagships!
I want to know how can we put back the back glass with adhesive
It’s will be a little difficult for this since it bonded with a very high force adhesive.
Qing Liu -
Thanks for video ) I'm interesting, Oneplus 6 mirror/midnight models have the same as color and material frames (not battery cover) or not?
Hi i have a oneplus 6, i bought when its release, after that phon droped in swiming pool now i can’t see anything on screen but still i am getting calls and vibrate ring tune all working fine but can’t see anything on screen, can someone help me with this situation.
Your display is gone. Now you have two possibilities: You can get a display from an online store and do it yourself, or you can send your phone to OnePlus, the replacements are actually not as expensive as in case of Samsung and Apple for example.
The chances are that OnePlus will deny to repair your phone though. By repairing your phone they have to guarantee the working of the replaced part, which in case of water damage is really unpredictable. After water damage every device could die any minute, technically. Most brands refuse to replace anything on water damaged devices.
Trying to fix my girlfriend's phone for her birthday - which is tomorrow!
Replaced the screen on the OnePlus six - was very careful so thought I'd done a good job. When I plug the phone in it vibrates and responds to pushes of the power and volume buttons, but I see nothing on the screen. What do I do?
Check the connection cables. Probably either the cable plug on the screen or on the Mobo are damaged. If that doesn't work send it to OP. As long as it hasn't got water damage they will repair it
Helyx -
I am curious to know how waterproof is the device. Any improvements over the 6?
Can i replace Volume button?
I dropped my oneplus 6 in the water and screen wasn’t going on so i bought a replacement and fixed it my self and now the screen works again :) Now my 2nd problem is that i dont have any sound from the bottom speaker and i bought a replacement but no luck so i guess its tied to something on the motherboard? Call speaker and headphone jack still works so i have no clue on what to do next and hope someone on here can help me?!?
I snapped the connector of the white cable connected to the motherboard. Does anyone know what it does?
Aidan Chui - 返信
io nell'aprire la cover ho strappato quel piccolo cavetto bianco che corre lungo tutto il telefono, a che cosa serve?????
