はじめに
必要な工具と部品
ビデオの概要
- There are no proprietary screws.
- The OnePlus 5’s display is held on by easy to dispatch reusable plastic clips.
- Most components such as the cameras and USBC/headphone jack flex cable are modular and easy to access.
- The battery has a pull tab making removal easy, but the motherboard must be removed to access it.
- The display and glass are fused and the home button is integrated into the display assembly making repair of all three of these parts more complicated and expensive.
まとめ
リペアビリティのスコア
7
10点中7点のリペアビリティ
(10点が最も修理しやすい指標です)
(10点が最も修理しやすい指標です)
16 件のコメント
Wow!! it is good, thank you.
Kaye - 返信
Wonderful video as usual. If one were to take theirs apart would it be as 'tight' once it was back together?
I think the buttons edges are a little sharp and I'm tempted to take it apart to put a little bevel on them.
I'd like it if the screen didn't end up being loose or have gaps around the back cover.
David - 返信
Is there an audio DAC founded? Can you tell us wich is it?
David Sepúlveda - 返信
The Snapdragon 835 has a built in DAC+amp with up to 4W output. https://www.qualcomm.com/products/snapdr...
George A. -
for those who dont have yootube and chance of a standard layout detaillng this teardown...?
P Stephenson - 返信
