メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのOculus Rift Sを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Oculus Rift S controller Teardown, Oculus Rift S controller Teardown: 手順 1、 3の画像 1 Oculus Rift S controller Teardown, Oculus Rift S controller Teardown: 手順 1、 3の画像 2 Oculus Rift S controller Teardown, Oculus Rift S controller Teardown: 手順 1、 3の画像 3
    • Remove battery, and the sticker underneath.
    • Picking a corner with a tweezer then grip and turn with the tweezer is a good way to remove the sticker.
    • Remove the two T5 torx screws.
    • Push firmly and turn to avoid slipping and stripping.
  2. Oculus Rift S controller Teardown: 手順 2、 2の画像 1 Oculus Rift S controller Teardown: 手順 2、 2の画像 2
    • Using a pry tool, start near the strap and pry away grip portion until it starts to hinge from the top.
    • Carefully pull back and down to remove the grip, clearing the grip trigger's hinge.
  3. Oculus Rift S controller Teardown: 手順 3、 1の画像 1
    • Remove the two T5 torx screws below the trigger.
    • Remember to apply pressure when removing the screws.
  4. Oculus Rift S controller Teardown: 手順 4、 3の画像 1 Oculus Rift S controller Teardown: 手順 4、 3の画像 2 Oculus Rift S controller Teardown: 手順 4、 3の画像 3
    • Using a straight-edge, wedge the inner ring away from the outer starting at the seam to separate the sensor array. Pull the sensors down carefully.
    • Be careful. The sensors are attached by ribbon cabling and could be easily damaged. The safest pry location is near the seem towards the bottom.
    • While pulling down on the sensors, push the outer ring towards the buttons. A uncomfortable amount of force is required to separate.
  5. Oculus Rift S controller Teardown: 手順 5、 1の画像 1
    • Insert wisdom here.
  6. Oculus Rift S controller Teardown: 手順 6、 2の画像 1 Oculus Rift S controller Teardown: 手順 6、 2の画像 2
    • Remove two T5 torx screws near the trigger to separate the cover for the buttons.
    • Hold the cover down while turning the controller upside down to avoid spilling the buttons.
    • Unscrew four T5 torx screws around the controller to separate the bottom PCB. One is facing outwards near the trigger. Three others are opposite from the battery compartment.
  7. Oculus Rift S controller Teardown: 手順 7、 2の画像 1 Oculus Rift S controller Teardown: 手順 7、 2の画像 2
    • Lift the wires up, and then remove the handle. Make sure to disconnect the wire or you may sever it.
    • The PCB also serves as the surface for the spring backing the trigger. Re-inserting the PCB with the handle still attached (for instance when cleaning) will require a separate tool to push the spring back while positioning the PCB back into place.
  8. Oculus Rift S controller Teardown: 手順 8、 2の画像 1 Oculus Rift S controller Teardown: 手順 8、 2の画像 2
    • Lift the flap to disconnect the circuit board from the body.
    • To disconnect the thumbstick, pull the black bar towards the thumbstick slightly to release the wires. Do not try to lift the 'flap' as isn't one!
作成者
5人の作成者と共同で作成されました。
Minicoin
メンバー登録日: 01/17/21
157 ポイント
1ガイドが承認済み
2 件のコメント
is there a place to get individual parts for the controller?
Luke Hodges - 返信
Can you use oculus 2 location ring flex cables for these? You can’t seem to find any parts for these controllers anywhere
Leprosy - 返信
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 56
過去 30 日: 104
今までの合計 4,144
