メインコンテンツにスキップ
この分解は進行中です。 – 最新版を見るには定期的に再読み込みします。
必要な工具と部品
  1. Nvidia Shield Controller Teardown, Nvidia Shield Controller Teardown: 手順 1、 2の画像 1 Nvidia Shield Controller Teardown, Nvidia Shield Controller Teardown: 手順 1、 2の画像 2
    • Nvidia Shield Normal Controller, without Display, so it's just a controller if you don't have other shield device
    • Micro-USB 2.0
    • 3.5 mm stereo headphone jack
    • Charge indicator
    • Still don't know how this controller connected to PC without cables, the controller can be connected to a Nvidia Shield through WiFi but no idea if this works with pc.
  2. Nvidia Shield Controller Teardown: 手順 2、 3の画像 1 Nvidia Shield Controller Teardown: 手順 2、 3の画像 2 Nvidia Shield Controller Teardown: 手順 2、 3の画像 3
    • Flipping over the device reveals 6 screws. No hidden screws here.
    • 6*screws, use T7 screwdriver for all of screws。
    • Careful, you will need some force to open the clips holding the device together.
    • Once you are inside the device remove the two ribbon cables.
  3. Nvidia Shield Controller Teardown, Vibration Motors: 手順 3、 2の画像 1 Nvidia Shield Controller Teardown, Vibration Motors: 手順 3、 2の画像 2
    • Remove two cable for the vibration motors and one cable for the battery.
    • There are 2 Vibration motors
    • Remove the two screws holding the logic board to the device.
    • Carefully remove the logic board.
  4. Nvidia Shield Controller Teardown, Battery: 手順 5、 2の画像 1 Nvidia Shield Controller Teardown, Battery: 手順 5、 2の画像 2
    • we can found battery part under the motherboard
    • Screw*4
    • LC18650 Lithium-ion Battery: 3.6V/2200mAh/7.92Wh
  5. Nvidia Shield Controller Teardown, Motherboard: 手順 6、 2の画像 1 Nvidia Shield Controller Teardown, Motherboard: 手順 6、 2の画像 2
    • Main PCB - Front:
    • TLV320AIC3204 (Very Low-Power Stereo Audio CODEC)
    • Atmel ATXMEGA32A4U-AU (8-bit Microcontroller)
    • Potentiometers
    • Main PCB - Back:
    • Microchip SST25WF020A (SPI Flash 2Mbit 1.8V)
    • Ozmo2000 431-B0 (WiFi Integrated Chip)
    • ADG3 3088CP (Unknown)
  6. Nvidia Shield Controller Teardown, LT&RT: 手順 7、 3の画像 1 Nvidia Shield Controller Teardown, LT&RT: 手順 7、 3の画像 2 Nvidia Shield Controller Teardown, LT&RT: 手順 7、 3の画像 3
    • Remove 6*screw
    • careful,don't broke the potentiometer
  7. Nvidia Shield Controller Teardown: 手順 8、 3の画像 1 Nvidia Shield Controller Teardown: 手順 8、 3の画像 2 Nvidia Shield Controller Teardown: 手順 8、 3の画像 3
    • cover part
    • 4*screw
    • PIC32MX120F032D-I/PT (32-bit Microcontroller)
    • PIC18F26K22-I/ML (8-bit Microcontroller)
作成者
4人の作成者と共同で作成されました。
13314877
メンバー登録日: 11/24/15
90 ポイント
1ガイドが承認済み
18 件のコメント
Where is the Shield console teardown?
Steve Hanson - 返信
I brought the controller to the hardware store and found that a T6 fit perfect. I bought it and used it, worked fine. I know the description says T7. May be a mistake
Farrid Mailloux - 返信
Farrid is Correct I have both a T7 and T6 Screwdriver and the T7 IS TOO BIG!, T6 fits perfectly. Just a heads up to anyone who needs to go out and but a Single screwdriver.
drestine -
You are right. It’s T6, not T7.
nguyen bui thanh -
Looking to replace ribbon cables. Anyone know where i can buy them?
Dave Miller - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 36
今までの合計 11,428
