この分解で使用される工具
はじめに
The Symbian^3 powered N8 is regarded as Nokia's direct competitor to the iPhone 4, as well as all the Android smartphones on the market. Betting the farm on the success of the N8, Nokia has packed this phone full of awesome features.
Join us today as we tinker our way to the heart of Nokia's freshest smartphone.
Our latest victim -- Nokia's just-released N8.
Technical specs:
ARM11 680 MHz processor
640 × 360 (nHD), 3.5" capacitive, multi-touch display with AMOLED technology
256 MB SDRAM
512 MB internal NAND memory and 16 GB on-board memory
12 Megapixels (main) with Carl Zeiss optics and Xenon flash, 16:9 720p video, 25 FPS
The 12 MP auto-focus camera is a honker. As we've seen in other smartphones, the thickness of the camera drives the thickness of the phone.
According to Dr. Hubert Nasse, the lens inside the camera module is composed of five individual aspherical shaped optical elements. This complex shape facilitates very high quality pictures out of a very small device.
Nokia chose to have the camera protrude outside of the back cover, which could either provide a good grasping point when taking the phone out of your pocket, or make it a hassle when returning the phone to your pocket.
Aside from a standard 3.5mm stereo headphone jack, the N8 features both a mini HDMI and a micro USB port. Not sure what to do with that HDMI port? Try setting a world record.
Buttons include: Power, Home, Hold, Camera, and Volume Switch.
The SIM and MicroSD ports are mounted side by side on the exterior of the phone, allowing for hot-swapping of the MicroSD.
Hey look at that -- visible T4 Torx screws! We figured this was a good place to start to take it apart.
A trifle later the bottom portion of the phone was off. If we only had one of these...
Link <these> only goes to Staple's general search page.
After popping off the protective cover, a T5 Torx screw near the mini HDMI port can be removed.
The top of the phone comes off next, exposing more Torx screws for us to remove.
"The top of the phone comes off next" in this tutorial only :-(
I was not able to go on the "t5 unscrew": top cover seems to be "solidly attached"
The cover is retained by 2 plastic lockers and needs some stress to pull off
http://d3nevzfk7ii3be.cloudfront.net/igi...
You need to apply a lot of pressure. For example by applying your thumbs on the back side of the cover and push in the back-to-front direction:
The front part of the phone opens up like a clam.
Thankfully the glass is not fused to the face of the AMOLED display, so you don't have to replace both if just the glass breaks.
The silk screen on the back of the display reads:
AMS347FF01-0
The silk screen also indicates the display was manufactured February 2, 2010. This thing has been around for quite some time.
The touch screen controller is a Synaptics T1201A. This is the same chip found in the Microsoft Kin Two and RIM Blackberry Torch.
Here's a comparison of the N8's display with an LCD from the 4th generation iPod Touch. You can differentiate between LCD and AMOLED screens by noticing the slightly blue tint the AMOLED display gives off when a light is shone against it.
That is a comparison picture. Read the text.
After the mid-plane is removed, the motherboard can be simply lifted out of the rear case.
The daughter board at the top of the motherboard has an interesting design in that it is connected to the main motherboard via a ribbon cable that is sandwiched between the many layers of the motherboard.
After years of pushing/pulling the USB cable, the micro USB connector main have false contact over time. Initially I though it was due to oxidation with transpiration. Actually I found the soldering of the 5 leads was all broken. The plastic part of the connector is very short so the mechanical constrain is supported by the liaison of the 5 leads by soldering on the main board. A refresh of these solderings and it's all back to normal!
The Nokia N8 motherboard:
Toshiba THGBM1G7D4FBA13 K23538 (16 GB Internal Memory)
Samsung K5W4G2GACA - AL54 (CPU + DDR RAM + NAND ROM)
Broadcom BCM2727 GPU with dedicated 3D Graphics
4380044 9920Q VJ (RF Transceiver) from STMicroelectronics
EPCOS D1053 (RF Front end module)
RENESAS 09801A (RF Power amplifier)
4376057 GAZ0035G (Baseband) from Texas Instruments
Can you tell if there is any underifll around ? looking at the pictures i cant see any and comparing it to iphone.. that one has a lot of it
With the motherboard out of the rear case, the flash unit simply lifts out.
As opposed to many other smartphones that use either a single or double LED for the flash, the N8 uses a Xenon flash tube similar to the kind of flash found in full-size cameras.
The large capacitor on the flash module supplies the high voltage necessary to produce such a brilliant flash.
Nokia N8 Repairability: 8 out of 10 (10 is easiest to repair)
The battery, although considered by Nokia not to be user-serviceable, can be easily removed.
The AMOLED display easily comes apart from the glass, which means that you can replace the glass and the display independently.
There are mostly mechanical fasteners, and very little glue inside.
You still have to use a heat gun to remove the front glass, but at least you're heating up metal that won't deform as easily as plastic.
Removing the cameras is near-impossible, and requires tedious, potentially detrimental steps.
Are you sure the main camera can't be removed? To me it seems like you can pop it right out of that metal frame, just like on many other mobile phones.
Certainly the main 12MP camera can be removed, if you have the right tool - the N8 service manual[1] on page 20 shows the 12MP camera being removed with an extraction tool (Camera Removal Tool SS-182).
1. http://db.tt/JpBJ7S (PDF)
6 件のコメント
I love the way they've managed to hide an iphone screen cover in the n8 (step 11!) Nice touch!
………….….joke?
