メインコンテンツにスキップ
はじめに
I'm going to open my old Nokia phone to have a look.But I only have very limited English writing skills and I hope you'll understand what I'm talking about.
この分解は修理ガイドでは ありません。 お持ちのNokia 6108を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Hello,I'm going to open my phone for some fun.
    • Hello,I'm going to open my phone for some fun.
    • Be careful not to drop any screws or parts when you're opening your phone.This may render your phone not usuable.Open your phone at your own risk.
  2. Remove the following parts. Battery cover
    • Remove the following parts.
    • Battery cover
    • Battery
    • SIM card
    • Remove two trox screws marked in figure 2.
  3. Remove the front panel by pulling it or using an I don't have a opening tool.So I used a flathead screw driver instead.
    • Remove the front panel by pulling it or using an
    • I don't have a opening tool.So I used a flathead screw driver instead.
    • Be careful not the damage the number pad connector(highlighted in red).If you break it.You'll have to replace the entre front panel.
  4. Remove 5 trox screws that are holding the screen and the touch pad. Remove 5 trox screws that are holding the screen and the touch pad.
    • Remove 5 trox screws that are holding the screen and the touch pad.
  5. After removing the touch pad and the screen.You can remove the logic board from the case. The board seem don't want to leave its cozy home.
    • After removing the touch pad and the screen.You can remove the logic board from the case.
    • The board seem don't want to leave its cozy home.
  6. Let's start removing the parts under the logic board.
    • Let's start removing the parts under the logic board.
    • Parts need to be removed.
    • A motor
    • Charger connector
    • A speaker
  7. Removing the EMI shield.Pry around the edge of the shield to remove it.
    • Removing the EMI shield.Pry around the edge of the shield to remove it.
  8. Nothing under the EMI shield. I think we should stop here right now.There are pictures for all parts.
    • Nothing under the EMI shield.
    • I think we should stop here right now.There are pictures for all parts.
Honam1021
メンバー登録日: 2011年02月19日
349 ポイント
1ガイドが承認済み
コメント1件
i have same phone but it's keypad button's are not working.... can u help me that
Rohit Yadav - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 4,497
