メインコンテンツにスキップ
この分解は修理ガイドでは ありません。 お持ちのNokia 2 (TA-1029)を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Nokia 2 Teardown, Prepare your tools: 手順 1、 1の画像 1
    • Prepare your tools before starting the repair.
    • I have a random multi-set screwdriver laying around, but it doesn't have T2 head.
  2. Nokia 2 Teardown, Pry open the back casing: 手順 2、 2の画像 1 Nokia 2 Teardown, Pry open the back casing: 手順 2、 2の画像 2
    • Open the back casing with your fingernail or a plastic pick.
    • Once you disconnect the back casing, you can use a pry tool or some other kind of resistive tool to lift the back panel.
  3. Nokia 2 Teardown, Pay attention to the screws: 手順 3、 1の画像 1
    • Unscrew the seven screws with your T5 screwdriver.
    • These screws should be removed with your T2 screwdriver.
  4. Nokia 2 Teardown, Unscrew the screws: 手順 4、 2の画像 1 Nokia 2 Teardown, Unscrew the screws: 手順 4、 2の画像 2
    • Prepare your T5 screwdriver.
    • Unscrew as marked in Step 3.
  5. Nokia 2 Teardown, Remove the back of the inner casing: 手順 5、 2の画像 1 Nokia 2 Teardown, Remove the back of the inner casing: 手順 5、 2の画像 2
    • Use a spudger or anything that is thin and sturdy (not a piece of paper).
    • A piece of paper is not ideal to remove the inner casing because it may rip. A ruler will also work.
    • Take your tool and place between the back cover and the device. Lift the tool until the motherboard is exposed.
    • Be careful when opening it! If you break the plastic, there is no way to reassemble it to make it new again.
  6. Nokia 2 Teardown, 1st part summary: 手順 6、 1の画像 1
    • This is the motherboard.
    • This is the big mammoth, the 4000mAH battery.
    • This is where our charging module sits.
    • This is the speaker itself.
    • This is where the Taptic Engine resides.
  7. Nokia 2 Teardown, Let's dig more in! Detach all flex cable in the phone: 手順 7、 2の画像 1 Nokia 2 Teardown, Let's dig more in! Detach all flex cable in the phone: 手順 7、 2の画像 2
    • Before the moment of truth, let's detach more cables.
    • Do not break the flex cable. Damaging the flex cable may result in a non-working phone. Please be careful!
  8. Nokia 2 Teardown, Squeeze out the battery: 手順 8、 2の画像 1 Nokia 2 Teardown, Squeeze out the battery: 手順 8、 2の画像 2
    • Use the spudging tool (used on step 5), Remove the battery from the slit shown and cut it.
    • The second picture shows what it will look like.
  9. Nokia 2 Teardown, Make more of it!: 手順 9、 3の画像 1 Nokia 2 Teardown, Make more of it!: 手順 9、 3の画像 2 Nokia 2 Teardown, Make more of it!: 手順 9、 3の画像 3
    • Repeat the process as shown in Step 7.
  10. Nokia 2 Teardown, Unscrew the screws on the motherboard and charging module: 手順 10、 2の画像 1 Nokia 2 Teardown, Unscrew the screws on the motherboard and charging module: 手順 10、 2の画像 2
    • To avoid further damage, remove the screws first.
    • If you do not remove the screw and just proceed to the removal, you will damage the board, resulting in your phone being irreversibly broken.
  11. Nokia 2 Teardown, 2nd summary: 手順 11、 1の画像 1
    • The green marks the 1GB RAM made by SK hynix
    • The red marks the Qualcomm Snapdragon 212. Unfortunately, this chip only supports ARMv7 so you can only play a little bit of games
  12. Nokia 2 Teardown, Pry off the screen: 手順 12、 2の画像 1 Nokia 2 Teardown, Pry off the screen: 手順 12、 2の画像 2
    • Use an iOpener and a spudger to open it.
    • If you can't afford those like me, you can use a hair dryer and some cards.
    • If you pry it open improperly, the LCD screen inside may be cracked, thus you'll have to do screen replacement to reconstruct it.
  13. Nokia 2 Teardown, Summary: 手順 13、 1の画像 1
    • Here is the device fully broken down.
作成者
1人の作成者と共同作成されました。
Zean
メンバー登録日: 07/20/21
217 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 31
今までの合計 1,100
