はじめに
If the speaker suddenly malfunctions, and you want to pull it apart to see what happened, this guide will show you how.
必要な工具と部品
Remove the rubber feet. There will be four screws.
Remove the screws and gently pry out the bottom piece.
Remove the two screws above the USB charging port and pry out the back panel.
Remove the four screws that hold the grill down.
Pull the grill out.
5 件のコメント
How to reset this speaker?
Rey Cornel - 返信
I dont think it can be reset. Assuming it’s pairing issues, maybe try looking up the datasheet for the bluetooth chip. There might be some info.
Lee -
I think it would be better to just buy a replacement speaker since the rubber ring is very hard to replace on drivers this small. Any 4-ohm driver with the same mounting holes will do. Be sure to seal the enclosure after replacement for better sound.
Lee -
