メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのNintendo GameCube Controllerを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Nintendo GameCube Controller Teardown, Separating the Separate Halves:: 手順 1、 2の画像 1 Nintendo GameCube Controller Teardown, Separating the Separate Halves:: 手順 1、 2の画像 2
    • Remove the six phillips head screws from the underside of the controller.
    • After these screws are removed, you can separate the bottom from the top of the controller.
  2. Nintendo GameCube Controller Teardown, Removing the Control Panel and Buttons:: 手順 2、 2の画像 1 Nintendo GameCube Controller Teardown, Removing the Control Panel and Buttons:: 手順 2、 2の画像 2
    • After removing the back of the controller, you can lift the circuit board out of the plastic shell.
    • With the circuit board removed, you can access the main buttons and remove them if desired.
  3. Nintendo GameCube Controller Teardown, Removing the Remotes Bumpers:: 手順 3、 2の画像 1 Nintendo GameCube Controller Teardown, Removing the Remotes Bumpers:: 手順 3、 2の画像 2
    • To remove the left and right bumpers from the bottom of the controller, pull up on the square base that keeps the button in place and then pull the button through the shell.
  4. Nintendo GameCube Controller Teardown, Pieces of the Controller:: 手順 4、 1の画像 1
    • These are the parts that should come out of the remote; not regarding the control panel.
  5. Nintendo GameCube Controller Teardown, Removing the C-Stick:: 手順 5、 2の画像 1 Nintendo GameCube Controller Teardown, Removing the C-Stick:: 手順 5、 2の画像 2
    • Once the control panel is removed from the controller the c-stick can be easily, but carefully, removed.
作成者
2人の作成者と共同で作成されました。
Pete Moreno
メンバー登録日: 06/02/15
154 ポイント
1ガイドが承認済み
5 件のコメント
So uh... This isn't an official GameCube controller. The official ones have Nintendo branding above the start button as well as a differently colored mainboard and tri-wing screws instead of Phillips. There are other slight differences in some components too. Do you mind someone else redoing this teardown with an official controller?
sigoshi - 返信
That would be awesome! Please do! =)
Sam Goldheart -
i will gladly do so in the next few weeks
ZeldaAwesome -
so is this with the official controllers now or has it still not been updated yet?
thanhan287 - 返信
This is pretty close to the official controller. I’ve submitted a separate guide for the official controller teardown.
Skeletwing -
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 14
過去 30 日: 67
今までの合計 16,220
