分解
この分解は修理ガイドでは ありません。 お持ちのNikko La Nera Juniorを修理する際は、iFixitの修理ガイドをご利用ください。
The Car, the Remote Control and a Phillips screwdriver.
Let's start!
Remove this screw.
The rear wing
Unscrew this black screws
Remove the wing
The Exhausts
Remove these screws
Remove the exhausts
The Rear Cover
The "tubolar" body
Flip the car
Remove these screws.
Remove the body
The seat
Remove these screws (one of these is back of the seat)
Remove the seat.
The antenna
Remove this screw
Raise the circuit board
Remove the antenna
The "engine"
Remove the gears cover
Remove the engine block
Remove the gear and his hinge
Remove this piece of plastic
The Engine!
Remove the wheels from the car
The Steering Mechanism
Remove the cover
Lift the wheels
Remove the steering bar...
...the two screws...
...and the cover.
Remove the first "gear"...
...and the second.
Remove the steering motor
Remove the plastic cover
Be careful!
Remove this piece
Remove the second piece...
...and the spring.
Congratulations! The car is torn down!
Let's tear down the remote!
Remove the screw in the PCB
Remove the screw in the piece of plastic at the end of the antenna
Remove the plastic piece around the beginning of the antenna
Carefully de-route the antenna from the PCB
Detach the two parts of eat key.
Congratulations! You've ended the teardown!
3人の作成者と共同で作成されました。
メンバー登録日: 06/12/11
306 ポイント
2のガイドは作成済み
バッジ: 8
+5 個以上のバッジ
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 1,794
