メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのNexus Sを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Nexus S Teardown, Nexus S Teardown: 手順 1、 2の画像 1 Nexus S Teardown, Nexus S Teardown: 手順 1、 2の画像 2
    • The Nexus S is a variation of the Samsung Galaxy S, sporting more or less the same hardware specifications as its brethren.
    • Notable changes to the Nexus S include NFC (Near Field Communication) support and a Super AMOLED Contour Display.
    • Tech Specs:
    • 1 GHz ARM Cortex-A8 Hummingbird Multimedia Applications Processor based on the ARMv7 architecture.
    • 16 GB internal storage capacity
    • 512 MB total RAM
    • 5 MP rear-facing camera and a VGA (640x480) front-facing camera.
    • Android 2.3 (Gingerbread)
  2. Nexus S Teardown: 手順 2、 2の画像 1 Nexus S Teardown: 手順 2、 2の画像 2
    • A side-by-side comparison of the Samsung-made Nexus S and its HTC-manufactured older sibling, the Nexus One.
    • It's not just an optical illusion, the Nexus S is smiling at you! This is the first smartphone to feature a Contour Display, meaning the display glass is slightly curved to be more comfortable for users.
  3. Nexus S Teardown: 手順 3、 2の画像 1 Nexus S Teardown: 手順 3、 2の画像 2
    • Without any further ado, let's start tearing this phone apart!
    • The entire back cover comes right off without a fuss, giving us a first glimpse of the battery.
    • We used a plastic opening tool to peel the NFC antenna module off the back cover. According to Google: "Nexus S can read information from 'smart' tags, or everyday objects that have NFC chips in them. These can be anything from stickers and movie posters to t-shirts."
    • Looks like something straight out of Tron: Legacy.
    Red one it is NFC antenna.
    Alexey Sitnikov - 返信
  4. Nexus S Teardown: 手順 4、 2の画像 1 Nexus S Teardown: 手順 4、 2の画像 2
    • The battery is extremely easy to remove and comes out next.
    • The 3.7 V, 5.55 Watt-hours Lithium ion cell provides up to 6.7 hours of talk time on a 3G network, and up to 14 hours on a 2G network.
    • The battery inside the Nexus S is rated at 1500 mAh. That's slightly higher than the 1400 mAh rating of the Nexus One's battery.
    • Don't feed this battery to a baby.
  5. Nexus S Teardown: 手順 5、 3の画像 1 Nexus S Teardown: 手順 5、 3の画像 2 Nexus S Teardown: 手順 5、 3の画像 3
    • After removing six screws with our trusty Phillips #00 screwdriver, a little prying with a plastic opening tool lets us remove the inner case.
  6. Nexus S Teardown: 手順 6、 2の画像 1 Nexus S Teardown: 手順 6、 2の画像 2
    • Taking out the motherboard requires removing three Phillips screws and disconnecting a few cables here and there.
    • The design of the motherboard is peculiar to us. It is designed such that its inner perimeter encloses the battery. We've seen oddly-shaped PCBs before, but rarely do they have giant holes in the middle of them.
    Can you be more specific on "few cables". =D
    Victor Araujo
    Victor Araujo - 返信
    We are more specific when we write repair guides. However, as we state above, "teardowns provide a look inside a device and should not be used as disassembly instructions."
    David Hodson -
    Just changed my screen according to this guide. There were two cables.
    Thomas Mardh
    vajsing -
  7. Nexus S Teardown: 手順 7、 2の画像 1 Nexus S Teardown: 手順 7、 2の画像 2
    • A handy plastic opening tool helps separate the SIM card reader from the rest of the motherboard.
    • The Nexus S is unlocked right out of the box and can be used with a Quad-band (850, 900, 1800, 1900) GSM carrier and is Tri-band HSPA (900, 2100, 1700) compatible.
    • For you AT&T customers out there, just a quick reminder that the Nexus S does not support the 850 MHz and 1900 MHz HSPA frequency bands required for 3G mobile data.
    NXP it is NFC chip, also it loop like it support SWP ( SIM as secure element for Mobile paying systems )
    You can clearly see the NFC chip to the right of the SIM tray. It's a NXP one. And those two metal contacts over the chip are the NFC antenna ones.
    arldn - 返信
  8. Nexus S Teardown: 手順 8、 2の画像 1 Nexus S Teardown: 手順 8、 2の画像 2
    • Much like the Samsung Galaxy S, the Nexus S features both a rear and front-facing camera.
    • Interestingly, the two cameras share the same connector on the motherboard and can be removed as a singular unit.
    • The front-facing VGA camera provides a resolution of 640 x 480 pixels.
  9. Nexus S Teardown: 手順 9、 2の画像 1 Nexus S Teardown: 手順 9、 2の画像 2
    • The EM-Tech EME1511AFRC integrates the earpiece speaker, loudspeaker for speakerphone and media use, and a sensor bank all into one unit with a singular shared data connector.
    • This is definitely a win for integration, but at the same time forces users to replace the entire unit if only one component malfunctions.
    This component is actually two distinct components which are sold seperately. Is the sensor bank housed inside the plastic box with the loudspeaker, or attached to the flex ribbon cable along with the proximity sensor and earpiece?
    Jerome C - 返信
  10. Nexus S Teardown: 手順 10、 2の画像 1 Nexus S Teardown: 手順 10、 2の画像 2
    • Big players on the motherboard include:
    • Skyworks SKY77529 Tx Front-End Module for Dual-Band GSM / GPRS / EDGE
    • SanDisk SDIN4C2 16GB MLC NAND flash.
    • Samsung KB100D00WM-A453 memory package and S5PC110A01 1GHz Cortex A8 Hummingbird Processor.
    • Infineon 8824 XG616 X-Gold baseband processor
    • Wolfson Microelectronics WM8994 ultra-low power audio codec.
  11. Nexus S Teardown: 手順 11、 1の画像 1
    • Hidden underneath an EMI cover is the Broadcom Wi-Fi chip.
    • The chip reads: BCM4329GKUBG TE1043 P21
    • According to UBM Techinsights, the chip is a low-power package with 802.11n, Bluetooth 2.1, and FM capability.
    • Variants of this chip have been around for over a year. We first saw it used in the 3rd generation iPod Touch.
  12. Nexus S Teardown: 手順 12、 2の画像 1 Nexus S Teardown: 手順 12、 2の画像 2
    • Removing the display presented us with the first stumbling block in our disassembly. A heat gun made quick work of the front case assembly, though.
    what heat gun would be good to use??
    christian gonzalez - 返信
    Could you go into more detail on step 12? Where do I have to heat and where to put in the opening tool? Is it glued together?
    srinne - 返信
  13. Nexus S Teardown: 手順 13、 2の画像 1 Nexus S Teardown: 手順 13、 2の画像 2
    • Here you can see a side view of the Super AMOLED display and front glass panel.
    • The Super AMOLED is attached to the front glass. The digitizer is a PET layer between the glass and the display.
    • You can definitely see that only the front glass panel is curved. The rest of the components are flat as a board, just as any other phone on the market.
    • Google describes it as a "...curved glass screen...", however that may be misconstrued to mean a curved Super AMOLED display, which is a bit misleading.
    • There's also a small PCB on the back of the display with an Atmel MXT224 touchscreen controller on it.
    so i smashed my screen on the nexus s . the bottom buttons still light up so i bought a outer screen for it not sure if i bought the right thing can u tell me what i might need.
    sharif - 返信
  14. Nexus S Teardown: 手順 14、 2の画像 1 Nexus S Teardown: 手順 14、 2の画像 2
    • Nexus S Repairability Score: 7 out of 10 (10 is easiest to repair)
    • Battery is very easily replaceable -- just remove the back cover to swap it out.
    • The motherboard comes out easily once you're inside, as it's held in place by regular screws and connectors.
    • A lot of the phone's components are modular, meaning that they're simpler to replace, but will cost more as replacement parts.
    • Front panel is attached with adhesive instead of screws, so it's harder to take off than on the iPhone.
    • If you shatter the front panel glass, the SAMOLED has to be replaced as well -- they're fused together.
作成者
14人の作成者と共同で作成されました。
Miroslav Djuric
158,326 ポイント
144のガイドは作成済み
7 件のコメント
Can you tell me where the GPS antenna is located?
Bernhard - 返信
The "few cables" made me cut the earphone contactas of the EM-Tech EME1511AFRC part, have to use it with the speaker to hear anything...
Besides the screen is heavily glued onto the front case (not kept in place by the outside "ring" of the phone), since I can't glue it, I gave up with my brand new screen & packed it back. Now, the screen is damaged and the earphone is off.
Too bad I did not see the "teardowns provide a look inside a device and should not be used as disassembly instructions." thing !
michel - 返信
Hint for Step 9: The earpiece-ribbon-cable-assembly and loudspeaker are actually two separate pieces, you can buy each one individually (e.g. on ebay).
I just disassembled mine to replace the screen bezel. Thanks for the teardown, it really helped me!
Thomas Sanladerer - 返信
Thanks for this good guide!
I was trying to know the correct voltage of the battery on step 10. Mine is 1.8 Volt
My Nexus S is not booting anymore. I had to reboot multiple times to have a chance to boot but actually it's dead.
The problem is that it cannot mount sd card.
I'll try to put the PCB in a oven to repair this.
Romain Rosset - 返信
Can anyone comment on the location - and replaceability – of the cell radio antenna? Note: I am not asking about the Wifi, GPS, or NFC antennas. The phone I have has gone deaf on its cellular radio only. I am hoping it's something as simple as a cold solder joint, but I need to know where the cellular antenna is in order to track this down.
lyndon - 返信
my nexus black out, anyone know what happened and where to buy the main board please??
meipie - 返信
What is the part number of the Bluetooth Chip here?Manufacturer?
Raul Piper - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 34
今までの合計 476,753
