メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのNexus 4 Wireless Chargerを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Nexus 4 Wireless Charger Teardown, Remove the round rubber face from the charging orb: 手順 1、 1の画像 1
    • Remove the round rubber face from the charging orb
    • Behind the rubber face is a thin sheet of plastic, you'll need to pierce it to access the 4 screws holding the device together.
  2. Nexus 4 Wireless Charger Teardown: 手順 2、 1の画像 1
    • The screws are located at 12 o'clock, 3 o'clock, 6 o'clock and 9 o'clock, just inside the outer ring.
    • You will need to unscrew these if possible, on my unit they were glued in and I was unable to unscrew them. Instead I used a drill with a 1/8" bit to drill them out.
    • If you drill them out be careful as they are surrounded by a PCB, though I drilled into the board a bit and it still functions. Once you remove the screws use the spudger to pry the shiny black plastic face off the base.
    • You will see the seam where the shiny and matte plastic meet on the unit. There are 4 plastic clips holding it down, once they are unclipped you can remove the shiny black faceplate exposing the charging coil and main PCB.
  3. Nexus 4 Wireless Charger Teardown: 手順 3、 1の画像 1
    • Next gently pull up on the main PCB and swing it to the right. There are wires connecting the main board to the micro usb port beneath, so be gentle.
    • You will see a single screw holding down the board with the micro usb connector, unscrew it and you're done.
作成者
1人の作成者と共同作成されました。
David Spalding
メンバー登録日: 11/12/15
6,473 ポイント
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 20
今までの合計 2,684
