必要な工具と部品
Wedge between the frame and back cover with an isesamo and separate all of the retaining clips
The connector slides out towards the outside of the device, and mine was pretty sticky so be careful.
Disconnect the LCD ribbon cable from the top and bottom of the battery. It is unnecessary to peel it off of the battery.
Disconnect the digi cable from the top right of the back of the device.
Remove the 5 speaker assembly screws and pry off the assembly
At this point you can also lightly pull the battery away from the back of the LCD. There isn't much adhesive holding it in place.
Remove the 5 motherboard screws and gently separate it from the back of the lcd.
At this point, the only thing left should be the display assembly
Use a heat gun or hot plate to separate the digitzer and glass from the frame
Before heating the frame its a good idea to remove the camera from the frame so it's not damaged.
13 の人々がこのガイドを完成させました。
8 件のコメント
The screen is crack the screen is on when I hit the home button it won't work
I replaced screen and now screen won't light up
ruger32016 - 返信
my touch screen does’nt respond can it be replace and where could i get one and what is the price. Im from mauritius thk
My touch screen does’nt respond is this can be change and where can i get one and what the price i’m from Mauritius
