メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのNeXTstationを修理する際は、iFixitの修理ガイドをご利用ください。
  1. NeXTstation Teardown, NeXTstation Teardown: 手順 1、 3の画像 1 NeXTstation Teardown, NeXTstation Teardown: 手順 1、 3の画像 2 NeXTstation Teardown, NeXTstation Teardown: 手順 1、 3の画像 3
    • The NeXTStation, this is a great addition to any computer collection.
  2. NeXTstation Teardown: 手順 2、 3の画像 1 NeXTstation Teardown: 手順 2、 3の画像 2 NeXTstation Teardown: 手順 2、 3の画像 3
    • Turn the NeXTStation around, and remove this screw:
    • Then, lift the top cover of the computer. This will reveal the guts.
    • The ports from left to right: SCSI2, Keyboard & Mouse, DSP Port, DB-19(MegaPixel Display), DB-9(Serial), RJ-45(Ethernet), Coaxial (10b2 Ethernet), Power
    • I find notes in everything!
    " Keyboard & Mouse"
    Nope! Those are serial ports. The keyboard plugs into the monitor, and the mouse plugs into the keyboard.
    Also the DB-9 is the printer port, by which the NeXT laser printer was attached. I don't think it could be used for general serial communications. On the other hand, if I recall correctly the DSP port *was* usable for high-speed serial communications.
    jonhendry - 返信
  3. NeXTstation Teardown: 手順 3、 2の画像 1 NeXTstation Teardown: 手順 3、 2の画像 2
    • Removing the hard drive:
    • The NeXTStation uses a 50-Pin SCSI Hard Drive up to 4GB.
    • Remove all of the cables from the logic board.
    It's incredible how modern this board looks, despite its being so dated.
    tabormeister - 返信
    tabormeisterからの引用:
    Yep, this was one fast of a workstation back in 90"
    Chris Green - 返信
  4. NeXTstation Teardown: 手順 4、 3の画像 1 NeXTstation Teardown: 手順 4、 3の画像 2 NeXTstation Teardown: 手順 4、 3の画像 3
    • Then remove this screw.
    • Once the screw is removed, pivot the drive up on a 45 Degree angle, then slide it out.
    Wow, it is so easy to take everything out!!! Now there are milions of screws and connectors, turning devices around and so on... I'm amazed of the simplicity!
    jakub004 - 返信
  5. NeXTstation Teardown: 手順 5、 1の画像 1
    • The Hard Drive & Caddy
  6. NeXTstation Teardown: 手順 6、 3の画像 1 NeXTstation Teardown: 手順 6、 3の画像 2 NeXTstation Teardown: 手順 6、 3の画像 3
    • Removing the floppy disk drive:
    • The NeXTStation uses a non-standard 2.88MB 3.5" floppy drive, though it uses the standard floppy connector.
    • Remove the floppy cable.
    • Then, remove this screw.
  7. NeXTstation Teardown: 手順 7、 3の画像 1 NeXTstation Teardown: 手順 7、 3の画像 2 NeXTstation Teardown: 手順 7、 3の画像 3
    • Then, just like the hard drive, pivot the drive up 45 degrees, and pull it out.
  8. NeXTstation Teardown: 手順 8、 3の画像 1 NeXTstation Teardown: 手順 8、 3の画像 2 NeXTstation Teardown: 手順 8、 3の画像 3
    • Removing the fan:
    • Remove this connector.
    • Remove these screws.
    • Remove the fan.
  9. NeXTstation Teardown: 手順 9、 3の画像 1 NeXTstation Teardown: 手順 9、 3の画像 2 NeXTstation Teardown: 手順 9、 3の画像 3
    • Removing the logic board:
    • Remove the power supply connector. Just lift it straight up, and it should come free.
    • Remove this screw.
  10. NeXTstation Teardown: 手順 10、 3の画像 1 NeXTstation Teardown: 手順 10、 3の画像 2 NeXTstation Teardown: 手順 10、 3の画像 3
    • Lift the end of the logic board(away from the ports), and slide it away from the ports.
    • Now, set the board aside.
  11. NeXTstation Teardown: 手順 11、 3の画像 1 NeXTstation Teardown: 手順 11、 3の画像 2 NeXTstation Teardown: 手順 11、 3の画像 3
    • Power Supply:
    • Lift the power supply up, and out.
    The power supply is the (only?) weak spot on this beauty! It is always the MOSFETs which burn out. So make sure you use heat sink compound when you re-assemble it!
    If it is broken, maybe this page can help: http://heller.no-ip.org/~heller/NeXT/pow...
    Helmut Heller - 返信
  12. NeXTstation Teardown: 手順 12、 1の画像 1
    • The Logic Board Overview:
    • The Board has a 25Mhz Motorola 68040 CPU, This board features a ton of chips for something made nearly 20 years ago.
    • The CPU: Motorola XC68040RC25
    • The Co-Procesor: MB610313
    • Motorola Chips
    • Intel Chips
    • AMD Chips (Intel and AMD In the same computer?)
    • Fujitsu Chips
    I think the MB610313 is a DMA controller ASIC.
    jonhendry - 返信
  13. NeXTstation Teardown: 手順 13、 3の画像 1 NeXTstation Teardown: 手順 13、 3の画像 2 NeXTstation Teardown: 手順 13、 3の画像 3
    • Made in the USA, you don't see this anymore.
    • The Serial #
    • Looks like my NeXTStation came from WilTel.
    • It is model # N1100
作成者
8人の作成者と共同で作成されました。
Chris Green
メンバー登録日: 10/11/09
36,978 ポイント
49のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,528のガイドは作成済み
3 件のコメント
http://www.youtube.com/watch?v=jhfUKEu7s...
The Machine to Build the Machines:
Watch NeXT's revolutionary computer controlled (NeXT Cubes - no less) assembly line in action!
Juddy - 返信
Juddyからの引用:
http://www.youtube.com/watch?v=jhfUKEu7s... The Machine to Build the Machines: Watch NeXT's revolutionary computer controlled (NeXT Cubes - no less) assembly line in action!
Amazing!
Chris Green - 返信
MB610313 - ICP (Integrated Channel Processor). Basically DMA on steroids for almost all of the main sub components of the system. I believe that the cube, or at least the 25Mhz 030/040 cubes, had two of these.
HotelCoralEssex - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 23
過去 30 日: 73
今までの合計 30,829
