メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのMotorola Moto G 1st Generationを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Motorola Moto G 1st Generation Teardown, Motorola Moto G 1st Generation Teardown: 手順 1、 3の画像 1 Motorola Moto G 1st Generation Teardown, Motorola Moto G 1st Generation Teardown: 手順 1、 3の画像 2 Motorola Moto G 1st Generation Teardown, Motorola Moto G 1st Generation Teardown: 手順 1、 3の画像 3
    • After removing the back cover, use a torx T5 to remove all screws at the back
    • Use an opening tool or plastic spuged to remove the outer frame.
  2. Motorola Moto G 1st Generation Teardown: 手順 2、 3の画像 1 Motorola Moto G 1st Generation Teardown: 手順 2、 3の画像 2 Motorola Moto G 1st Generation Teardown: 手順 2、 3の画像 3
    • First we're going to remove the battery
    • Using a plastic spudger, remove the battery connector from its socket.
    • The battery will come off the motherboard when you put a little bit of pressure under it.
    • Don't bend the battery too much
  3. Motorola Moto G 1st Generation Teardown: 手順 3、 1の画像 1
    • The naked motherboard will reveal 2 connectors (apart from the battery-socket)
    • This is the front-cam
    • This is the digitizer/LCD flex
  4. Motorola Moto G 1st Generation Teardown: 手順 4、 3の画像 1 Motorola Moto G 1st Generation Teardown: 手順 4、 3の画像 2 Motorola Moto G 1st Generation Teardown: 手順 4、 3の画像 3
    • To remove the camera, use a pair of tweezers to remove the tape
    • Next, use a plastic spudger to open up the socket.
    • Pull the camera up (out of the lens-socket) and pull so the flex will come out of it's socket
  5. Motorola Moto G 1st Generation Teardown: 手順 5、 3の画像 1 Motorola Moto G 1st Generation Teardown: 手順 5、 3の画像 2 Motorola Moto G 1st Generation Teardown: 手順 5、 3の画像 3
    • To remove the LCD/Digitizer connection from its socket, remove the blue silicone cover
    • Next, use a plastic spudger to open the socket-lock
    • Carefully remove the flex cable.
    • Although this flex seems to exist in 2 parts, it's actually removable as one. Only the wide flex has to be disconnected.
  6. Motorola Moto G 1st Generation Teardown: 手順 6、 1の画像 1
    • Now, it's only the motherboard that's left.
    • Use a fine plastic tool to pull the main board out
    • There are no screws at this step
    • Never put too much stress on the motherboard, find other places to put pressure if it doesn't cooperate immediately
  7. Motorola Moto G 1st Generation Teardown: 手順 7、 1の画像 1
    • All done
    • The earpiece remains in the screen assembly. Take care when removing it from the screen. Push gently on it from the screen-side to lift it out.
作成者
10人の作成者と共同で作成されました。
Maxim
メンバー登録日: 04/30/14
2,297 ポイント
3のガイドは作成済み
チーム
iFixers Belgium iFixers Belgium人のメンバー
Business
1 メンバー
5のガイドは作成済み
22 件のコメント
The procedure is very simple, but i realise that take off all the screws is a little bit difficult. As well, remove the motherboard that is attached to the plate behind the screen.
Allan Alcantara - 返信
Question. How difficult is it to replace the glass?
Abigail McElroy - 返信
I'm just about to have a go at it now!
I'll let you know
Dan Cameron -
Just replaced the broken screen on my XT1039. Be aware XT1032,XT1033, XT1039 - the screen components are all the same. I bought the screen/frame/digitizer as one unit for the XT1032. It was relatively straight-forward with a bit of care and attention in certain areas. After you've taken the 14 screws out the rest of the phone is basically glued together with sticky-strips. I followed the advice on a You-tube video and used a hair dryer to heat up the ribbon cables and to loosen the earpiece. Phone now fully functional - hooray! Thanks to all on this forum!
camiano - 返信
Can we further dismantle individual elements on motehrboard? Like I want to replace the memory.
simplyviral - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 18
過去 30 日: 64
今までの合計 88,395
