メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのMotorola Droid 1を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Motorola Droid Teardown, Motorola Droid Teardown: 手順 1、 3の画像 1 Motorola Droid Teardown, Motorola Droid Teardown: 手順 1、 3の画像 2 Motorola Droid Teardown, Motorola Droid Teardown: 手順 1、 3の画像 3
    • Thar she blows! Keep it locked on iFixit and PhoneWreck to see all of the details as they become available!
  2. Motorola Droid Teardown: 手順 2、 1の画像 1
    • The first step is to remove the backcover and Battery
    • Here you'll see two screws
    • Use your T6 to remove both the Black and Silver Screws.
    • There are more screws but they are non-conveniently hidden. Finding these was the hardest part!
    Torx size is a T5 NOT A T6!!!
    acemn232 - 返信
  3. Motorola Droid Teardown: 手順 3、 1の画像 1
    • Non-conveniently, Motorola has made the chassis screws hard to find...
    • Two are located underneath the plastic piece at the top of the device.
    • Use a pin or very fine stiff wedge to lift this away from the double sided tape to reveal two more T6 screws.
  4. Motorola Droid Teardown: 手順 4、 1の画像 1
    • Finding the rest of the fasteners is a royal pain...
    • Did you think to look under the lens cover and google label? Probably not... you should! There's a T5 under there!
    • Try not to mind Dr. Wreck's massive toe thumbs...
  5. Motorola Droid Teardown: 手順 5、 1の画像 1
    • You're not done yet! You still need to dig for fasteners at the bottom of the device!
    • Luckily there are really *not* easy to find. See that gold grill underneath the battery cover? Yeah... peel that away.
  6. Motorola Droid Teardown: 手順 6、 1の画像 1
    • With these screws removed, you can pry away the back part of the chassis.
    • Use a wedge and work it carefully around the outside of the frame.
  7. Motorola Droid Teardown: 手順 7、 3の画像 1 Motorola Droid Teardown: 手順 7、 3の画像 2 Motorola Droid Teardown: 手順 7、 3の画像 3
    • There it is!
    • Use the T5 to remove the last silver PCB screw.
    • Pull off the flex cables that fast the top of the logic board to the screen portion.
  8. Motorola Droid Teardown: 手順 8、 1の画像 1
    • Now you can flip out the PCB.
    • Remove the flex off of the bottom of the PCB to free it.
  9. Motorola Droid Teardown: 手順 9、 1の画像 1
    • Lastly, pry away the black frame that surrounds the keyboad of the device. This will unveil the sliding mechanism.
  10. Motorola Droid Teardown: 手順 10、 3の画像 1 Motorola Droid Teardown: 手順 10、 3の画像 2 Motorola Droid Teardown: 手順 10、 3の画像 3
    • We removed the Cans (not a recommended step!!!) to see what IC's were on the board.
    • Check out the Block Diagram for full details!
    The OMAP 3430 is made by Texas Instruments and not Qualcomm. You can't see the manufacturer, since the memory is a POP (Package on Package) configuration.
    http://focus.ti.com/general/docs/wtbu/wt...
    gbraad - 返信
  11. Motorola Droid Teardown: 手順 11、 1の画像 1
作成者
9人の作成者と共同で作成されました。
drwreck
メンバー登録日: 11/11/09
1,446 ポイント
11のガイドは作成済み
3 件のコメント
Headphones were tugging or yanked enough to wear out the connection, and I found these instructions invaluable. It was enough for me to get the back panel off.
The back panel has the headphone jack (visible in your last image). I stretched the spring connectors out to give more pressure, but the real problem were the pads on the flex connector -- a couple of them had holes worn in them. I applied a light coat (a dab, followed by a touch from the desoldering braid) of solder to the pads, reassembled the unit, and it works like a charm. I hope this helps anybody who has a flaky headphone connection.
Ridicalis - 返信
Another good note would be to mark what "Droid" your making a manual for. You did fairly well but please remember Droid is only the brand and there are literally tons of models for example there is the Droid X2, X3, Droid Razr, etc. and when I was looking at this I thought it would help but this guide is absolutely useless when trying to open or fix my Droid Maxx HD since they are completely different.
Cosimo Bressi - 返信
I am attempting a digitizer replacement on my a855. The phone is disassebled (screws all accounted for luckily) and just got the glass piece re-taped into the bezel. Having trouble finding where the connector for the digitizer reconnects? The phone came apart and I could not see the connection point for the digitizer ribbon connector.
Thanks
Stephen Bricker - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 49
今までの合計 119,652
