はじめに
This disassembly will show you how to remove the logic board as well as the lcd.
必要な工具と部品
5 件のコメント
Brilliant! Many thanks. Things to watch: the volume rocker and on switch tend to fall out, so secured them to the back with a little bit of masking tape while I reassembled. Helped to slightly lift one end of the motherboard so the case can go around the USB power socket. After that it fits back together with only minor persuasion.
Hi,
my Search "button" stop lightning. The other 3 "buttons" are ok.
Did someone know the reason?
Thank you!
Help! I bought a t5 torx screwdriver to open my motorola and the screwdriver seems too smal! Wtf? Many dismount video says that this is a t5 model, I don't understand...
Pierre Flq - 返信
can you mark ram on that board ?
