メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのMicrosoft Surface RTを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Microsoft Surface Teardown, Microsoft Surface Teardown: 手順 1、 2の画像 1 Microsoft Surface Teardown, Microsoft Surface Teardown: 手順 1、 2の画像 2
    • Is that the display assembly from a PC laptop? Nope, it's the new Microsoft Surface with Windows RT.
    • Notable tech specs:
    • 10.6" ClearType HD Display (resolution of 1366x768 pixels)
    • Quad-core NVIDIA Tegra 3 processor
    • 2 GB RAM
    • 32 or 64 GB flash storage
    • Wi-Fi (802.11a/b/g/n) + Bluetooth 4.0
    • 720p HD Front and Rear facing LifeCams
    Is this tuto valid for a surface go ? This one has a very bad reputation for repair.
    privacy.private - 返信
  2. Microsoft Surface Teardown: 手順 2、 3の画像 1 Microsoft Surface Teardown: 手順 2、 3の画像 2 Microsoft Surface Teardown: 手順 2、 3の画像 3
    • To give the Surface laptop-like connectivity, nearly every edge includes ports and buttons. They are (from left to right):
    • Magnetic charging, USB 2.0, and Micro-HDMI out on the right side
    • Magnetic connection for the Touch Cover or Type Cover on the bottom
    • Headphone jack and volume rocker on the left side
  3. Microsoft Surface Teardown: 手順 3、 2の画像 1 Microsoft Surface Teardown: 手順 3、 2の画像 2
    • Just like your first big-kid bike, this laptop tablet comes with a kickstand to prop it up in notebook mode.
    • One of the most notable features of the Surface is its Touch Cover keyboard, which protects the screen when closed and provides a full QWERTY typing experience when open.
    • For users who find the Touch Cover to be too much a compromise, Microsoft offers the Type Cover, a chiclet keyboard that also folds up to protect the Surface's LCD.
  4. Microsoft Surface Teardown: 手順 4、 3の画像 1 Microsoft Surface Teardown: 手順 4、 3の画像 2 Microsoft Surface Teardown: 手順 4、 3の画像 3
    • We begin our expedition by removing the kickstand.
    • Fun fact: the kickstand is held in place by a few Torx screws.
    • Sans kickstand, we can easily view the markings on the back of the Surface's rear case. The Surface with Windows RT has a model number of 1516.
    Savez vous ou je pourrai trouver une nouvelle béquille?
    jahmin - 返信
    Where can I get hold of these screws, my RT has lost a kiskstand screw?
    kenn1ewb - 返信
    My kickstand lost its kickstand screw as well
    Matthew Elert - 返信
  5. Microsoft Surface Teardown: 手順 5、 3の画像 1 Microsoft Surface Teardown: 手順 5、 3の画像 2 Microsoft Surface Teardown: 手順 5、 3の画像 3
    • Small bezels tend to hide screws, so the first place we look to open the Surface is its long plastic camera cover.
    • Our pictures make it look easy, but removing this plastic cover took about half an hour and a lot of careful prying.
    • Chalk it up to inexperience. This step should take less than ten minutes once we create guides for it.
    • Not only did we find the screws we were searching for, but there is also what appears to be a tamper-evident seal that simply reads "Surface."
    • The tamper-evident label is composed of multiple sections. Unfortunately, it breaks apart upon removal.
    "Are you ready to break the Surface?" (re: tamper seal)
    apoJj - 返信
    MS make removing their warranty seals harder over time.I still remember how easy to remove the original Xbox 360 seal without damging it.
    Honam1021 - 返信
    There is also a screw under the SURFACE sticker
    Paul - 返信
    Can you please give more detail on how to remove the camera cover?
    Minh Le - 返信
    I used a very small Screwdriver and began at the side furthest from the power switch and gently pry it up. As you move along you will see where it clips and can gently nudge the clips to release and the camera cover area comes right off. Before you remove the screws under the camera cover, check Microsoft to make sure your surface isn't under warranty, because a screw is under that seal and will have to be removed. To replace it start at the power switch side and gently snap into place all the way across.
    Marie McNutt - 返信
    I used a cutter knife and slid it right underneath the camera in the gap, pushing it away from the camera towoards the flipstand gave just enough space to put a pry tool in between the cameracover and the backcover. Moving that tool towards the right and the left side you will se the clips you need to pull out. For the clips nearest to the screen start at the right side (viewed from the back) an make your way to the left.
    Needed about 5 min removing this part (including the time finding the best way to get in that gap)
    Johannes M. Seifert (Jormsen) - 返信
  6. Microsoft Surface Teardown: 手順 6、 3の画像 1 Microsoft Surface Teardown: 手順 6、 3の画像 2 Microsoft Surface Teardown: 手順 6、 3の画像 3
    • After removing a total of 17 T5 Torx screws, (10 under the kickstand and 7 under the camera cover), the rear case comes right off—almost.
    • A lone ribbon cable still tethers the battery to a ZIF connector on the Surface's motherboard, which we make quick work of with the ever-trusty spudger.
    Great explanation of the RT. I recently took mine apart as I was having problems with it charging. In the process the ZIF battery connector came off so right now I can only get power thru the charger instead of any battery power. I am trying to locate a zif connector for the RT, would you know a part number or specs. Appreciate any help you can provide. thanks
    scbryson21 - 返信
    Were you ever able to find one? I have the same problem.
    C Hafner - 返信
  7. Microsoft Surface Teardown: 手順 7、 2の画像 1 Microsoft Surface Teardown: 手順 7、 2の画像 2
    • The big question of the day: is the battery easily removed?
    • Answer: Yes. It's glued in, but it's way easier to remove than on the iPad. A couple of minutes of spudging around, and it's out.
    • We get our first look at the battery. As is the norm, the dual battery cell is adhered to the VaporMg rear case.
    • The 7.4 V, 31.5 Wh battery is manufactured by Samsung. It fits right in between the iPad 2's 25 Wh battery, and the iPad 3's 42.5 Wh unit.
    Can you provide the xyz dimensions of the 2 battery cells in the battery pack?
    Jarvis Tou - 返信
  8. Microsoft Surface Teardown: 手順 8、 3の画像 1 Microsoft Surface Teardown: 手順 8、 3の画像 2 Microsoft Surface Teardown: 手順 8、 3の画像 3
    • Next we find a large orange ribbon cable leading to the "Apple-esque" magnetic charging port. The microSDXC card slot that hides underneath the kickstand is also attached to this ribbon cable. And not a single bother was given that day, so we proceeded to dismantle the speakers.
    • We love modular components inside tablets and smartphones, and these speakers fit that bill. A little bit of spudgering, and our Surface has gone silent.
    • With two speaker assemblies we are living in stereo.
    Would you have any info on a part number for the charging port, or suggestions of where to track one down? I'm pretty sure I need to replace one for a family member, which should be pretty easy (thanks to you guys), but I still need the part to do the job.
    Matt Wilson - 返信
    X868156-002 - Power Adapter Port Assembly
    azamudiogarcia -
    You forgot to mention the T3 screws that hold the ribbon in place.
    Jason Zak - 返信
    Your comments are a1. I love it lmao keep it up
    Roger Santiago - 返信
  9. Microsoft Surface Teardown: 手順 9、 3の画像 1 Microsoft Surface Teardown: 手順 9、 3の画像 2 Microsoft Surface Teardown: 手順 9、 3の画像 3
    • Next to the display in the front case we find, well, some speaker-looking thing.
    • Inside the case of our mystery component we found a voice coil, so we're pretty sure it's some sort of microphone or secondary speaker, or possibly a linear vibration motor.
    • Update: It looks like a Precision Microdrives Precision Haptic Linear Resonant Vibrator, responsible for haptic feedback.
  10. Microsoft Surface Teardown: 手順 10、 2の画像 1 Microsoft Surface Teardown: 手順 10、 2の画像 2
    • The headphone jack and volume buttons aren't holding on to their real estate too tightly, and they easily come out next.
    • We still count this as a modular component, even though it's two things on the same ribbon cable. We have certainly seen worse lately as far as modularity goes.
  11. Microsoft Surface Teardown: 手順 11、 2の画像 1 Microsoft Surface Teardown: 手順 11、 2の画像 2
    • We disconnect the display and digitizer cable from the motherboard with the help of a plastic opening tool.
    • Let's get the motherboard out and see what goodies are attached to it.
  12. Microsoft Surface Teardown: 手順 12、 2の画像 1 Microsoft Surface Teardown: 手順 12、 2の画像 2
    • Oh no! We can't Skype with our grandmothers now that the front-facing camera is gone!
    • We had to wait until the motherboard was out to remove this camera, as a plastic bezel pins it down from beneath.
  13. Microsoft Surface Teardown: 手順 13、 2の画像 1 Microsoft Surface Teardown: 手順 13、 2の画像 2
    • Off comes another 720p camera from the motherboard. It feels like we've done this before…
    • The exclusion of a 1080p rear-facing camera either means cost was a big concern, or that Microsoft's designers don't expect you to use the Surface as your main camera.
    • Perhaps they too realized how goofy you might look when taking pictures with a tablet.
    One does look goofy using a tablet as a camera xD
    Roger Santiago - 返信
  14. Microsoft Surface Teardown: 手順 14、 1の画像 1
    I am pretty sure that the CY8C20466A is not driving the touchscreen or touch keyboard. The 5 Atmel devices are doing that. The maximum 4MIPS M8C cpu in the CY8C20466A is great for Button slider and wheel type ccap touch applications, but not powerfull enough for a screen. My guess is that they are either using it for some cap touch buttons along the edges of the Surface or they are using the switch cap functionality in the Cap sense block as an audio filter. The latter makes most sense when you consider the other devices on the module
    Sam Francisco - 返信
    Merhaba benim cihazımı açmaya çalıştığımda hiçbir tepki vermiyor. İçini açtım ve turuncu bölümün üzerinde küçük, kırmızı bir ışık yanıyor bunun anlamı nedir? Sorun ne olabilir?
    Metin Korkmaz - 返信
  15. Microsoft Surface Teardown: 手順 15、 1の画像 1
    • The backside of the motherboard doesn't have any chips, but it does have two Wi-Fi antennas, the ambient light sensor, a couple microphones, and a precarious wire running most of its length.
    • Ambient light sensor
    • Wolfson WM7220 Microphones
    • Precarious wire
    • The Wi-Fi antennas are labeled:
    • Antenova A10416-WIFI-A2
    • Antenova A10416-WIFI-A1
    The precarious wire is a wifi antenna cable. If you look where it goes, it comes from right underneath the wifi section of the board and goes to near the far away wifi antenna is. You can see where it comes through the board on the side far away form the wifi section, and that it goes to an antenna connection and other passives.
    It's not precarious at all, it's soldered in many places to the board to hold it in place (I wouldn't be surprised if all of those connections were connecting the shield of the cable to ground on the board.) That's a really which quality job for the wifi antenna.
    adcurtin - 返信
    That "precarious wire" does look like a piece of micro coaxial cable. I believe the technical term would be semi-rigid cable. They used that stuff on many handsets throughout the 1990's. If you have to traverse relatively long distances, it is hard to beat - you don't have the dispersion of the signal like you do with printed line.
    DanB - 返信
  16. Microsoft Surface Teardown: 手順 16、 3の画像 1 Microsoft Surface Teardown: 手順 16、 3の画像 2 Microsoft Surface Teardown: 手順 16、 3の画像 3
    • Following the mother(board) is the daughter(board) featuring three Atmel MXT154E touchscreen controllers.
    • This board only deals with matters pertaining to the 10.6" touchscreen. Everything else is either located on the motherboard or on its own ribbon cable.
  17. Microsoft Surface Teardown: 手順 17、 2の画像 1 Microsoft Surface Teardown: 手順 17、 2の画像 2
    • The back side of the daughterboard contains only a few prominent ICs:
    • Atmel MXT1386 touchscreen controller
    • TI MSP430G2402 Microcontroller
    • 1600P E284A Crystal Oscillator
    there is a Cypress touch screen controller and one from Atmel?
    DooMMasteR - 返信
  18. Microsoft Surface Teardown: 手順 18、 3の画像 1 Microsoft Surface Teardown: 手順 18、 3の画像 2 Microsoft Surface Teardown: 手順 18、 3の画像 3
    • We tried to remove the keyboard connector, but were disappointed to find it's wedged firmly under the LCD. Replacing the connector will require either bending the magnesium frame or separating the display.
    • We were on a teardown roll, so we pressed on and pulled the display from the VaporMG frame, which required a heat gun, some guitar picks, and plenty of patience.
    • The display's LTL106AL01-002 label indicates Samsung as the manufacturer. Its sister panel, the LTL106AL01-001, appears to be 1280 x 800 resolution. We didn't test the Surface's display before taking it apart, and we trust Microsoft not to lie…
    • But maybe someone can do a quicky double-check on the display resolution, just for giggles?
    owning a Surface I can confirm a resolution of 1366x768 for the display.
    shertaeg - 返信
    Do you know what adhesive was used to attach the LCD to the frame?
    Richard Jackson - 返信
    I also want to know.
    09D090 -
  19. Microsoft Surface Teardown: 手順 19、 2の画像 1 Microsoft Surface Teardown: 手順 19、 2の画像 2
    • Microsoft Surface Repairability: 4 out of 10 (10 is easiest to repair).
    • Several components are modular and replaceable without requiring desoldering.
    • You can remove the battery pretty easily—once you've suffered through the opening procedure.
    • It's pretty difficult to remove the rear panel and gain access to the device.
    • It is impossible to remove the keyboard connector without first removing the display from the frame.
    • LCD and glass are fused together and strongly adhered to the case, increasing cost of replacement.
    • You'll have to use a heat gun and lots of patience to gain access to the glass and LCD.
28 件のコメント
This site says the display LTL106AL01-002 has the 1280 x 800 resolution also...
http://www.alibaba.com/product-gs/664763...
Mile Zajkovski - 返信
This site states the proper resolution: http://xingkong.en.alibaba.com/product/6...
Life's the same, except for the shoes...
scottwilkins - 返信
What's the keyboard connector pinout?
Joseph Innace - 返信
This is cool. Eagerly waiting for a teardown of the touch and type covers as well...
Sreekumar S - 返信
What are the MEMS sensors inside of Surface?
Alex Hung - 返信
What are the Sensor Fusion solutions (Accelerometer, Gyroscope and Magnetometer) inside of Surface?
Alex Hung - 返信
Impossible to install a new mSATA drive to upgrade from 32GB to something better. sad
Bryan - 返信
Can the Samsung 32 GB flash drive be replaced? My Surface wont boot anymore and ive been told that is a Hard Disk problem.
Ioan Corbu - 返信
Hi my drive has gone after only 14 months of use.Did you find a solution & how easy is it to replace?
johngraham36 -
My RT got a cracked screen, and I'm ordering a new LCD as well as a separate digitizer bezel.
Anyone have any ideas on reattaching the LCD and the digitizer WITHOUT gluing them back together? I would like a solution that would make future repair easier with out breaking out the heat gun, and if I'm fortunate enough to once again NOT damage the LCD, but only the digitizer, NOT having it glued together would be great.
Joe Tom Collins - 返信
Last night i pluged it in for charging and slept . When i checked in the morning the display is not working. But under careful observation i found display working 5n but the backlight is not.
What is the solution to my problem?
Chaithanya - 返信
Hi Chaithanaya,
I have the same problem with my Surtface RT, went to sleep once and since then backlight isn't working.
Did you manage to get it to work?
Thanks
Karol -
Hi Chaithanya, I found the answer on other laptops to be a very small fuse connecting power from the motherboard to the LCD, its usually in the first or last place on the ribbon connector circuit. I haven't done that repair on a surface yet.
Dan Apted
CustomCPU
Anchorage, Alaska
danapted -
I have a big problem with my surface .not charging anymore.can you tell me how could i check the charger, the pin from the device. it is another way to check if the batery is good.
CATALIN TONI - 返信
clean the connection's with alcohol pads
lscoles48 -
I was given a couple of "dead" surface RTs with chargers. none of the little lights on charger plugs lit up when attached to any of the tablets. I found that by very slowly "rolling" the the plug on/in to the connector pins (and some times slowly up and down the length of the plug) that suddenly the light on the magnetic plug comes on. my theory (probably wrong) is the battery is so flat that simply connecting up the power charger won't start it. the battery needs a "spark" i.e. the gentle rolling of the plug in the magnetic socket. All of the 4 units I was given appeared dead initially. they hadn't been touched for months. All 4 units starting working (power light come on on the plug) by slowly rolling the plug in to the tablets magnetic power socket.
altomic -
Hi there
I have got Surface RT 64gb some how it doesn't give backlight I can see display but very very dim would you please recommend me what could be the problem
Regards
Nav
navida583 - 返信
i am replacing the digitizer and screen (right terms?) on this surface, and found this site very helpful, thanx!! Im new at this and cant get the zif connectors to release the old screen. Ive looked at dozens of videos on zifs and have carefully pried, pushed, pulled in every direction and cant get them to budge, any help?
nick
nick mostly - 返信
where is the ribbon cable? Is it under the LCD? I am trying to repair my Surface rt. It fell on the floor and stopped showing anything except the back light.
Ramandeep Kaur Mand - 返信
Anyone in here know how to start a MS RT that just get black after show the "SURFACE"?
Goran Eklund
Goran Eklund - 返信
scbryson21 - 返信
Tore mine down. Totally none upgradable flash drive.
Mines 64gb. Data lost.
Just went on black screen Surface pro......
Bruce Foster - 返信
Hello can you help me my tab has been suddenly stop working how can I fix it
Tulasiram - 返信
it's also my keyboard
sandra - 返信
Any guide I've been able to find online shows a number of screws visible under the kickstand once you remove it. The RT I have has no visible screws under the kickstand? I can remove the kickstand. The two screws to do so are located as annotated. Those are the only screws visible. There are no Torx screws around outside edge of surface rt under the kickstand. Furthermore, there are no Torx screws under the plastic cover around camera. Any guidance on how to get to the battery on this unit?
Didi 02/05/2017
Ananda Gaorii - 返信
Can i know please where is tge hard drive in tge surface rt??
trans-m1 - 返信
Can i replace the 32gb motherboard with a 64 one???
trans-m1 - 返信
Hi there,
This is a Tailor-made LCD Module, Customized LCDs manufacturer-RJOYTEK.
This site is 0.38"-24" TFT LCD display shop: https://rjoytek.com/
lcdsolution - 返信
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 69
過去 30 日: 322
今までの合計 337,539
