はじめに
This OneTouch 4 Mini hard drive was bought at a Fry's store in 2007. It has a 80 GB capacity, and a 8 MB Buffer.
The drive has an estimated read/write speed of 28 MB/s
I am tearing this apart so I can put this under Spinrite to fix the drive from a unreadable sector.
必要な工具と部品
This teardown is the same with the other onetouch 4 mini models.
The 2.5" hard drive in the Maxtor OneTouch 4 Mini isn't a Maxtor drive at all. It's a Seagate Momentus 5400.5 LD25.2 hard drive.
Here is the Seagate product overview to the Momentus 5400.2 hard drive, model number ST980210AS
Removing the EMF shield reveals a small PCB that plugs directly into the SATA and power connections of the Momentus 5400.5. It doesn't even have a physical connection to the RFI shield -- it just hangs off the back of the drive itself. The SATA connections to the drive are soldered to the PCB itself.
The controler board's chip is made by Initio. It is a Initio INIC-1605 USB to SATA Bridge Chip
