メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのMaxtor OneTouch 4 Miniを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Maxtor OneTouch 4 Mini Teardown, Maxtor OneTouch 4 Mini Teardown: 手順 1、 2の画像 1 Maxtor OneTouch 4 Mini Teardown, Maxtor OneTouch 4 Mini Teardown: 手順 1、 2の画像 2
    • This teardown is the same with the other onetouch 4 mini models.
  2. Maxtor OneTouch 4 Mini Teardown: 手順 2、 3の画像 1 Maxtor OneTouch 4 Mini Teardown: 手順 2、 3の画像 2 Maxtor OneTouch 4 Mini Teardown: 手順 2、 3の画像 3
    • The drive's enclosure doesn't have any screws or glue holding the case in place, it has a clamshell-style design that cradles the drive inside.
    • There is a seam at the bottom edge of the drive where the 2 halves comes apart. A flat head screwdriver helps pry it open.
  3. Maxtor OneTouch 4 Mini Teardown: 手順 3、 2の画像 1 Maxtor OneTouch 4 Mini Teardown: 手順 3、 2の画像 2
    • The drive is suspended in the middle of the enclosure by several foam rubber pads, which keeps the drive quiet and keep vibrations at a minimum.
    • The metal plate covering the lower part of the drive is an EMF shield, and is where the SATA to USB board is held in.
  4. Maxtor OneTouch 4 Mini Teardown: 手順 4、 2の画像 1 Maxtor OneTouch 4 Mini Teardown: 手順 4、 2の画像 2
    • Removing the shield is removing the 2 philips screws on the side of the drive where the shield is held in place.
    • Lets see what kind of chip and drive do we have here on the next step....
  5. Maxtor OneTouch 4 Mini Teardown: 手順 5、 1の画像 1
    • The other side of the drive. The sticker on the connector, is the serial number.
    • The controller board and the drive is connected using SATA.
  6. Maxtor OneTouch 4 Mini Teardown: 手順 6、 2の画像 1 Maxtor OneTouch 4 Mini Teardown: 手順 6、 2の画像 2
    • The 2.5" hard drive in the Maxtor OneTouch 4 Mini isn't a Maxtor drive at all. It's a Seagate Momentus 5400.5 LD25.2 hard drive.
    • Here is the Seagate product overview to the Momentus 5400.2 hard drive, model number ST980210AS
    • Removing the EMF shield reveals a small PCB that plugs directly into the SATA and power connections of the Momentus 5400.5. It doesn't even have a physical connection to the RFI shield -- it just hangs off the back of the drive itself. The SATA connections to the drive are soldered to the PCB itself.
    • The controler board's chip is made by Initio. It is a Initio INIC-1605 USB to SATA Bridge Chip
  7. Maxtor OneTouch 4 Mini Teardown: 手順 7、 1の画像 1
    • Just to keep in mind, taking your external drive apart would void the drive's warranty. It's just something to know if your external drive is under warranty.
    • Even though the hard drive's label reads "Not Suitable for Laptop Computer Use", it still works perfectly as a laptop hard drive.
作成者
1人の作成者と共同作成されました。
Peter Low
メンバー登録日: 03/26/11
281 ポイント
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 43
今までの合計 17,880
