メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのMacBook Unibody Model A1342を修理する際は、iFixitの修理ガイドをご利用ください。
  1. MacBook Unibody Model A1342 Mid 2010 Teardown, MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 1、 1の画像 1
    • The new revision of the MacBook Unibody Model A1342 has been kind enough to grace us with its presence.
    • Tech Specs:
    • 2.4 GHz Intel Core 2 Duo processor with 3 MB on-chip L2 shared cache.
    • NVIDIA GeForce 320M graphics processor with 256 MB of shared DDR3 SDRAM.
    • 10 hour 63.5 Wh lithium-polymer battery.
    • Mini Display port with audio out support. *GASP*
  2. MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 2、 2の画像 1 MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 2、 2の画像 2
    • Much like its predecessor, the lower case is held by eight Phillips #00 screws.
  3. MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 3、 3の画像 1 MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 3、 3の画像 2 MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 3、 3の画像 3
    • The battery looks very similar to the previous one. So similar, in fact, that it's identical in size and shape, and has the same model number (A1331).
    • Even so, it still makes continued use of Tri-Wing screws to secure the battery in place. Why Apple? Why? Why can't you free us from the oppression and tyranny that is Tri-Wing screws?
    • Be wary though...appearances can be deceiving, and that is certainly the case here.
    • The battery in the A1342 Mid 2010 is 63.5 watt-hours and weighs 355 grams.
    • In contrast, the earlier A1342 has a battery of 60 watt-hours and weighs 347.5 grams.
  4. MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 4、 2の画像 1 MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 4、 2の画像 2
    • Lo and behold, the new battery works in the A1342!
    • Both of these screenshots were taken from the previous iteration, the MacBook Unibody A1342.
    • You can get an extra 350 mAh of juice if you're willing to add 7.5 grams to your "older" MacBook.
  5. MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 5、 2の画像 1 MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 5、 2の画像 2
    この手順で使用する道具:
    T6 Torx Screwdriver
    $9.99
    購入する
    • After removing two Phillips screws and the hard drive bracket, lift the drive out of the MacBook by its pull tab and disconnect the SATA connector.
    • If you're installing a new hard drive, you'll need a T6 Torx screwdriver to transfer the mounting screws to your new hard drive.
  6. MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 6、 2の画像 1 MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 6、 2の画像 2
    • Removing the speaker assembly and AirPort/Bluetooth board requires a bit of work, but nothing we at iFixit can't handle.
    • Bluetooth model number is BCM943224PCIEBT.
    • This is the same card used in the previous model, the A1342.
  7. MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 7、 1の画像 1
    • After removing the final few screws, lift the optical drive out of its comfy abode.
    • You'll be glad to know that MacBook Unibody Model A1342 Mid 2010 continues to use the 8x SATA superdrive manufactured by Panasonic, model UJ898.
  8. MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 8、 2の画像 1 MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 8、 2の画像 2
    • Removal of the fan was no biggie. It simply required a Phillips screwdriver and a spudger.
  9. MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 9、 3の画像 1 MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 9、 3の画像 2 MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 9、 3の画像 3
    • Obviously the logic board needs to come out, or else this isn't a teardown.
    • With the flick of our trusty spudger, we continue to disconnect several connectors around the perimeter of the logic board, as well as removing the RAM.
    • Carefully maneuver the logic board assembly out of the upper case.
  10. MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 10、 1の画像 1
    • The heat sink must be removed prior to revealing the newly optimized processor and graphics chips.
  11. MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 11、 2の画像 1 MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 11、 2の画像 2
    • Parts numbers found thus far:
    • Intel Core 2 Duo Mobile Processor E006B705 SLDGZ AV80577P8600 2.40/3M/1066
    • NVIDIA GeForce 320M integrated chipset graphics card: The successor to the GeForce 9400M.
    • Realtek RTL8251CA GigE Ethernet
    • CYPRESS CY8C24 16 KB Flash PSoC
    • TDK 6T213HF
    • Cirrus Logic 4206ACNZ
  12. MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 12、 1の画像 1
    • The display assembly is secured by two large T8 screws, one on each side.
    • Shameless plug: We sell a screwdriver kit that will enable you to remove these screws.
  13. MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 13、 1の画像 1
    • In Apple's everlasting effort to aid in the reduction of environmental impacts, the LED-backlit display in the MacBook A1342 and Mid 2010 A1342 are Mercury-free.
    • Wondering how to replace the display assembly? Well look no further, simply follow these steps and you'll be up and running in no time.
    • Spoiler alert: Coming soon to a browser near you, replacing the LED-backlit display...stay tuned!
  14. MacBook Unibody Model A1342 Mid 2010 Teardown: 手順 14、 1の画像 1
    • Disclaimer: No MacBooks were hurt, in any way, shape, or form, during the process of this teardown.
    • Now that we've taken care of that legal mumbo jumbo that some people care about (most people don't), here is the final layout of what used to be a MacBook Unibody Model A1342 Mid 2010.
作成者
9人の作成者と共同で作成されました。
Miroslav Djuric
158,516 ポイント
144のガイドは作成済み
12 件のコメント
Step 3
New battery is 63.5 watts not 65
mkaz13 - 返信
Just wanted to let people know, the A1278 13" macbook pro 'black' keyboard is interchangeable with the 'white' 2009/2010 macbook A1342 .. It looks pretty cool to! :) . Just remove the metal bracket and use epoxy to stick the keyboard and metal bracket back on :). Cheers.
techetc - 返信
Including the Backlight? That'd be crazy awesome!
Maximilian Willert -
I don’t think the backlight would work because there is no hardware to power it present on the logic board of the MacBook
Isaiah Hollingworth -
Many thanks for this awesome teardown!
Maximilian Willert - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 37
過去 30 日: 125
今までの合計 190,188
