メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのLogitech V220 - Cordless Optical Mouseを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Logitech V220 - Cordless Optical Mouse Teardown, Removing the USB Wireless Receiver: 手順 1、 3の画像 1 Logitech V220 - Cordless Optical Mouse Teardown, Removing the USB Wireless Receiver: 手順 1、 3の画像 2 Logitech V220 - Cordless Optical Mouse Teardown, Removing the USB Wireless Receiver: 手順 1、 3の画像 3
    • Wash your hands before replacing the battery to prevent debris getting into the mouse and damaging its internal components.
    • Orient the mouse so you are viewing its base.
    • Using your fingers, gently remove the USB wireless receiver by sliding it towards you.
    • USB removal will result in the power switch to be in its ON position.
    • With your fingertip, engage the power switch to its OFF position to ensure the mouse is not powered.
  2. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Pads: 手順 2、 3の画像 1 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Pads: 手順 2、 3の画像 2 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Pads: 手順 2、 3の画像 3
    • Locate the four mouse pads.
    • Use the rectangular end of the metal spudger to get underneath each mouse pad, pry them up, and peel them off.
  3. Logitech V220 - Cordless Optical Mouse Teardown, Unscrewing the Mouse Housing Screws: 手順 3、 1の画像 1
    • Locate the four #0 Phillips screws where the mouse pads previously were.
    • Unscrew the four #0 Phillips screws with the Phillips #0 screwdriver.
  4. Logitech V220 - Cordless Optical Mouse Teardown, Separating the Mouse Housing: 手順 4、 2の画像 1 Logitech V220 - Cordless Optical Mouse Teardown, Separating the Mouse Housing: 手順 4、 2の画像 2
    • Once the housing screws are fully removed, slowly (and carefully) separate the top and bottom halves of the housing.
    • Rapid separation of the housing halves may result in damaging the power cables (red and black wires) and molex (white plug).
  5. Logitech V220 - Cordless Optical Mouse Teardown, Detaching the Top Mouse Housing: 手順 5、 2の画像 1 Logitech V220 - Cordless Optical Mouse Teardown, Detaching the Top Mouse Housing: 手順 5、 2の画像 2
    • Gently set the mouse halves down on a flat surface.
    • Secure the base half with one hand.
    • With thumb and forefinger, grab the end of the molex and pull it away from you until the molex is unplugged.
  6. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Scroll Wheel: 手順 6、 3の画像 1 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Scroll Wheel: 手順 6、 3の画像 2 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Scroll Wheel: 手順 6、 3の画像 3
    • Locate the one, scroll wheel, #0 Phillips screw near the very front edge of the mouse.
    • Turn the mouse 90 degrees clockwise.
    • While supporting the rear of the mouse base, unscrew the #0 Phillips scroll wheel screw.
    • Once the scroll wheel screw is fully removed, manually extract the scroll wheel and spring assembly.
  7. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Scroll Wheel Spring: 手順 7、 2の画像 1 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Scroll Wheel Spring: 手順 7、 2の画像 2
    • Locate the scroll wheel spring.
    • Use the tweezers to gently remove the spring by slowly tugging the spring away from the scroll wheel assembly.
  8. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Circuit Board: 手順 8、 3の画像 1 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Circuit Board: 手順 8、 3の画像 2 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Circuit Board: 手順 8、 3の画像 3
    • Locate and remove the circuit board screw.
    • Grip the edges of the circuit board.
    • Manually remove the circuit board from the base of the mold housing.
  9. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Buttons Screw: 手順 9、 1の画像 1
    • Locate and remove the #0 Phillips screw in the middle of the mouse.
  10. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Buttons: 手順 10、 3の画像 1 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Buttons: 手順 10、 3の画像 2 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Buttons: 手順 10、 3の画像 3
    • Flip over the top half of the mouse housing so you are viewing underneath it.
    • Locate the mouse button hooks.
    • Rotate the housing 180 degrees clockwise.
    • Using the spudger, firmly push down on each mouse button until the mouse button is released from the hook.
    • Viewing the front of the mouse, the left and right mouse buttons should be detached from the housing.
  11. Logitech V220 - Cordless Optical Mouse Teardown: 手順 11、 1の画像 1
    • Hold the housing so you are looking down the battery slot.
    • Place the flat end of the spudger between the mouse buttons and the housing.
    • Pry off the mouse buttons.
作成者
1人の作成者と共同作成されました。
Tyler Price
メンバー登録日: 04/07/14
948 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 6-2, Forte Spring 2014 Cal Poly, Team 6-2, Forte Spring 2014人のメンバー
CPSU-FORTE-S14S6G2
5 メンバー
20のガイドは作成済み
コメント 1 件
Tyler - Very good work on this and your other work on this mouse. I appreciate your attention to detail. I wonder if you are the T. Price who used to go to MacDonalds in U/A in 1995? Thanks again so much for your professional work!
Rik Lesel - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 63
今までの合計 4,142
