はじめに
Outline what you are going to teach someone how to do.
必要な工具と部品
Powercord with a micro USB connector
European plug adapter
American plug adapter
Harmony Hub
Micro USB cable
IR mini blaster
Since we didn't find any screws we expected them to be under the soft foot pads.
We easily removed them with a utility knife
Now we can see 4 screws and 2 openings to the PCB.
I wondered what they could be but my guess is that they're used to test the PCB.
The case opens up easily when using a utility knife around the sides
This is a cover paper to make sure the status LED doesn't shine in the rest of the casing but just to the front
Inside the top case we find a load to give the product a little more weight
As you can see the top case is made a little thinner on the places where an IR led is present
PCB was manufactured by a Chinese company called FCF
There are 6 IR leds spread over the PCB
CC2544 SoC 2.4-GHz RF Transceiver and antenna
CSR8811 bluetooth chip and antenna
WiFi antenna from the AR9331 on the other side of the pcb
MX25L12835F 128Mbits serial Flash memory
EM6AB160TSE-5G 512 Mbits SDRAM
AR9331 2.4 GHz 802.11b/g/n SoC for AP and Router Platforms
Micro USB (data and power) - Can be used to extend this hub with a Harmony Home Hub Extender
Reset/Pair button
2x IR mini blaster ports (2.5mm)
3 件のコメント
Extremely helpful, thank you. But I also want to know the location of IR input which is used to learning IR commands from original remotes.
