分解
This wireless router stopped working, so I wanted to take a look at it's innards.
この分解は修理ガイドでは ありません。 お持ちのLinksys BEFW11S4を修理する際は、iFixitの修理ガイドをご利用ください。
Waiting to be disassembled...
Remove antennas.
Remove nuts and washers around antenna connectors.
Push in antenna connectors.
Remove feet (with flat-head screwdriver, fingernails, etc).
Unscrew the screws.
Pull apart blue front from black back with a LOT of force.
Slide and pull up bottom. (Make sure the antenna connectors get through.)
Twist and pull out antenna connector feeds.
Pull up RF shield from motherboard.
Unscrew the motherboard from the bottom.
Push the motherboard forward (as in this picture) to unlatch it from the bottom.
Some people have a card where you have to unscrew it. If that is your case, do that. The instructions below is for my type of router.
Push the card forward to deattach the pins.
Remove the card from the metal holdster.
Here are the markings on the motherboard chips. If you have any info on these chips, please comment!
Macronix 29F040QC-90
ISSI IS41C16100S-50K
SAMSUNG ARM S3C4510X01-QERO
RMC RTL8019AS
Bothhands FB2022
Bothhands 40ST1041E
Kendin KS8995. Kendin has since been bought by Micrel.
Enjoy!
5人の作成者と共同で作成されました。
メンバー登録日: 04/18/10
65 ポイント
1ガイドが承認済み
バッジ: 1
what is that card inside this router
hartiTube - 2016年7月31日 返信
Thank you. I accomplished this task. Except my antenna wires were soldered to the board.
Darren - 2016年9月18日 返信
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
過去 24時間: 3
過去 7 日: 4
過去 30 日: 12
今までの合計 9,039
