メインコンテンツにスキップ
必要な工具と部品
ビデオの概要
この分解は修理ガイドでは ありません。 お持ちのLenovo Yoga 730-13IKBを修理する際は、iFixitの修理ガイドをご利用ください。
    • Insert wisdom here.
  1. Lenovo YOGA 730 13" Teardown: 手順 2、 3の画像 1 Lenovo YOGA 730 13" Teardown: 手順 2、 3の画像 2 Lenovo YOGA 730 13" Teardown: 手順 2、 3の画像 3
作成者
4人の作成者と共同で作成されました。
IT FIX
メンバー登録日: 10/16/17
6,340 ポイント
74のガイドは作成済み
9 件のコメント
Guten Tag. könnten Sie mir bitte sagen. wo man ein Ersatzscharnier rechts für das Modell Lenovo Yoga 730-13IKB , Core i5-8250U, 8GB RAM, 256GB SSD (81CT0023GE) finden kann? Danke im Voraus für Ihre Antwort.
Iurie Ciobanu - 返信
Why didn’t you completly pull the board out and show the cpu? Is it removable and upgradable?
Braheem Hazeem (Grumpy Wolf) - 返信
Most laptop cpu’s are soldered to their contacts. There’s very few models of laptop’s that will have removable cpu’s in the consumer market.
Matthew Dixon -
I’ve the yoga 30 13 inch FHD touchscreen. Anyone know if the 40 pin connector on the board would support a UHD touchscreen upgrade?
JT Cen - 返信
Teardown to me mean you strip it completely down to loose parts. This did not help me at all with removing the screen to replace hinges. This “teardown” is something a rookie should have made. I expect better ifixit.
bw_b_dub - 返信
Which one's the keyboard cable? Certain keys are only intermittently working. I think my keyboard connector might be loose.
S I - 返信
TP = Touch Pad
KB = Keyboard
PW = Power
IT FIX -
Photos are in really low quality. It would be awesome to be able to read the text in the ram chips :(
Anibal Montano - 返信
The “unboxing” portion was completely irrelevant… and a waste of time. Why do so many people think the unboxing is such a monumental event to document and publish…? Aside from that, I totally cringe each time I see purported professionals touching computer components with their bare fingers; this is especially so with the chips. Fingerprints contain corrosive elements that will “eat into” a component.
calbear70 - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 32
今までの合計 14,023
