メインコンテンツにスキップ
必要な工具と部品
ビデオの概要
この分解は修理ガイドでは ありません。 お持ちのLenovo ThinkPadを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Lenovo ThinkPad X1 Carbon 6th Gen Teardown, Lenovo ThinkPad X1 Carbon 6th Gen Teardown: 手順 1、 2の画像 1 Lenovo ThinkPad X1 Carbon 6th Gen Teardown, Lenovo ThinkPad X1 Carbon 6th Gen Teardown: 手順 1、 2の画像 2
    • Insert wisdom here.
    lol its not teardown haha, i need assembly guide for wwan cables, but as seems in this notebook neither wwan card, then also no factory assembled cables.
    tokisada - 返信
作成者
3人の作成者と共同で作成されました。
IT FIX
メンバー登録日: 10/16/17
6,340 ポイント
74のガイドは作成済み
8 件のコメント
computer quit - dark screen and no more life. Any ideas
nmenon - 返信
I experienced this too (dark screen, but otherwise laptop seemed to respond just fine… like caps and numlock keys were working, beep sound at boot). Attaching an external monitor gave image (after booting into OS). Re-seating the internal eDP connector fixed my issue (apparently it was a bad connection). I hope the cable is not damaged or so…
Tim Bruylants -
I wonder if thermal pads that look like grey foam are efficient at all. Thinking to replace them with the traditional ones.
Artem Nikolaev - 返信
Try to mesure the temp before and after it’s interesting
IT FIX -
I tried, conventional thermal pads are indeed more efficient, but back plate reaches very high temp. Reverted back.
Artem Nikolaev -
I still love my Thinkpad X1 G6. Had some issues with keyboard though. Unfortunately Lenovo refuses to repair keyboard in warranty. My left shift key kept popping out. My X1 is still under warranty, but Lenovo refused a repair and claimed “consumer induced damage” without having even seen it and other people having similar issues, especially with keys that are used often such as “e” or left shift etc. (see reddit, for example).
Fixing keys that keep popping out:
It’s possible to stick a small piece of Tesa powerstrip on top of the mount for the key clip and prevent the keys from popping out, you can find photos here as i wasn’t possible to add them here: https://blog.b-nm.at/2021/01/10/thinkpad...
gabi.baumgartner - 返信
Hi Tim Bruylants ,
I am having an issue where I replaced my cracked screen. After installing my new screen, the backlight is broken. Any suggestions? I tried reinstalling the old screen, and back light is not working anymore either.
Isaac Rubner - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 29
過去 30 日: 146
今までの合計 29,324
