必要な工具と部品
Locate the horizontal grip located on the back cover of the phone.
Slide the back cover down and off of the phone.
Locate the 5 screws holding the body of the phone together.
Using a Philips head screwdriver, twist counterclockwise to remove the screws.
Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
Locate the clamp at bottom right side of the Circuit Board.
Pull the circuit board from the phone being cautious to pull out underneath the clamp.
Locate the two rubber circles covering the screws.
Remove the rubber covers using tweezers.
Using the Phillips head screwdriver, unscrew and remove the two screws.
