この分解は修理ガイドでは ありません。 お持ちのLG VX8350 Repairを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Locate the horizontal grip located on the back cover of the phone. Slide the back cover down and off of the phone.
    • Locate the horizontal grip located on the back cover of the phone.
    • Slide the back cover down and off of the phone.
  2. Insert a plastic opening tool into the battery release point located above the battery. Pull outwards in order to release the battery.
    • Insert a plastic opening tool into the battery release point located above the battery.
    • Pull outwards in order to release the battery.
  3. Locate the 5 screws holding the body of the phone together. The top screw will have a plastic cover, remove it using tweezers. Using a Philips head screwdriver, twist counterclockwise to remove the screws.
    • Locate the 5 screws holding the body of the phone together.
    • The top screw will have a plastic cover, remove it using tweezers.
    • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
    • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
  4. Lift the back cover starting at the bottom of the phone. Lift the back cover starting at the bottom of the phone.
    • Lift the back cover starting at the bottom of the phone.
  5. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  6. Remove the back cover completely from the phone. Remove the back cover completely from the phone.
    • Remove the back cover completely from the phone.
  7. Locate the clamp at bottom right side of the Circuit Board.
    • Locate the clamp at bottom right side of the Circuit Board.
    • Pull the circuit board from the phone being cautious to pull out underneath the clamp.
  8. Locate the ribbon connecting the circuit board to the phone display. Using the spudger, disconnect the ribbon connecting the phone's display and the circuit board.
    • Locate the ribbon connecting the circuit board to the phone display.
    • Using the spudger, disconnect the ribbon connecting the phone's display and the circuit board.
    • Remove the circuit board
  9. Lift the keyboard and remove it from the phone. Lift the keyboard and remove it from the phone.
    • Lift the keyboard and remove it from the phone.
  10. Locate the two rubber circles covering the screws. Remove the rubber covers using tweezers. Using the Phillips head screwdriver, unscrew and remove the two screws.
    • Locate the two rubber circles covering the screws.
    • Remove the rubber covers using tweezers.
    • Using the Phillips head screwdriver, unscrew and remove the two screws.
  11. Close the phone and gently pull outwards from the bottom left portion of the phone cover. Take care not to do this with too much force, as it could crack the cover. Completely remove the cover from the phone.
    • Close the phone and gently pull outwards from the bottom left portion of the phone cover.
    • Take care not to do this with too much force, as it could crack the cover.
    • Completely remove the cover from the phone.
  12. You have now performed a complete teardown of the LG VX8350.
    • You have now performed a complete teardown of the LG VX8350.
Jonathan Flowers
メンバー登録日: 2013年10月18日
607 ポイント
6のガイドは作成済み
チーム
Clemson, Team 14-7, Benson Fall 2013 Clemson, Team 14-7, Benson Fall 2013人のメンバー
CLEM-BENSON-F13S14G7
3 メンバー
15のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 1,315
