メインコンテンツにスキップ
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのLG VX3200を修理する際は、iFixitの修理ガイドをご利用ください。
  1. LG VX3200 Teardown, Battery: 手順 1、 1の画像 1
    • Press button labeled "Push". In the photo depicted the button is being depressed by the left finger.
    • Pull back panel toward bottom of phone.
  2. LG VX3200 Teardown: 手順 2、 1の画像 1
    • From the lip on the top of the battery, lift it out of the phone.
  3. LG VX3200 Teardown, LG VX3200 Teardown: 手順 3、 1の画像 1
    • Remove the five screws from the back panel, under the battery.
    • There is a hidden screw under the rubber pad next to the antenna. To remove this pad use a screwdriver to pry out rubber.
  4. LG VX3200 Teardown: 手順 4、 1の画像 1
    • Starting at the top of the phone near the antenna, use a screwdriver or other small tool, maybe even fingernails, to pry the rear panel off.
    • There are 4 places where the panel snaps together to the main part of the phone.
    • By systematically prying up the edges of the back panel, moving about a quarter of an inch, and prying again, the panel will begin to lift off.
    • Don't be afraid to damage anything, the panel requires a bit of force to detach.
  5. LG VX3200 Teardown: 手順 5、 1の画像 1
    • In order to remove the back panel of the screen half of the phone, you have to remove the 4 screws.
    • First, open the phone and remove the 4 rubber pads that are around the screen. you can use a small screwdriver or a pin to pop them out.
  6. LG VX3200 Teardown: 手順 6、 1の画像 1
    • Remove the four screws using your Phillips head screwdriver.
  7. LG VX3200 Teardown: 手順 7、 2の画像 1 LG VX3200 Teardown: 手順 7、 2の画像 2
    • Similar to removing the panel underneath the battery, you need to pry the colored panel off of the top half of the phone.
    • There are 4 snap-in points and some sticky tape holding the panel on. Starting on the side nearest the antenna, pry off the panel, moving slowly around the panel.
  8. LG VX3200 Teardown: 手順 8、 2の画像 1 LG VX3200 Teardown: 手順 8、 2の画像 2
    • The logic board is only held on with 4 tabs. Simply pry from one side using a screwdriver, popping out the board.
    • Note that the logic board is still connected to the screen by an electrical ribbon.
  9. LG VX3200 Teardown: 手順 9、 1の画像 1
    • The speakers are held in by a sticky glue. Be careful not to break any of the components, simply pry slowly from underneath until the speakers pop out.
  10. LG VX3200 Teardown: 手順 10、 1の画像 1
    • To remove the screen, grab hold of one or more of the speakers and pry up using the connecting wire. The tape holding the screen in should lift up, and the screen should easily separate from the case.
  11. LG VX3200 Teardown: 手順 11、 1の画像 1
    • Detaching the two halves of the phone from each other takes a bit of force.
    • With the phone open, pry from the right side of the hinge with a screwdriver. Using a bit of force, pull apart the two halves.
    • Be careful not to tear the ribbon connecting the logic board to the screen.
作成者
7人の作成者と共同で作成されました。
Bradley Hutchinson
メンバー登録日: 01/19/10
42 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 5-9, Forte Winter 2010 Cal Poly, Team 5-9, Forte Winter 2010人のメンバー
CPSU-FORTE-W10S5G9
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 11
今までの合計 2,450
