はじめに
This is a simple teardown of the LG G watch R.
必要なもの
First remove the watch band using a small flat screw driver to compress the spring loaded pin.
Remove the four T4 torx screws (Green).
Carefully pry the base off using a thin flat screw driver
Disconnect the four electrical connectors from the board
Orange - Battery connector
Blue - button and charging connector
Green - Backlight
Purple - O-LED Controller + Mic
Remove the three phillips screws securing the board down. Then lift the board off the base
The battery is below the board.
The battery can easily be pried out using a small flat head screwdriver.
Using a small pliers and a small flat screwdriver the battery housing comes out easily.
8 件のコメント
Is there a wifi antenna inside the LG G watch R?
Yes, there is a WiFi antenna inside the LG G Watch R, however WiFi functionality was only recently added to the G Watch R in a more recent update via Android Wear.
Are there differences between the UK as US G Watch R?
