はじめに
My Kobo Forma e-reader stopped charging. So I stripped it down.
I thought it would be a faulty battery but the battery seems to be OK. But the motherboard doesn't think it is charging (when it is) and shuts down if I boot it up.
There is very little to fix inside but the motherboard does have what looks like a serial debugging port. Pins labelled TX/RX/V and ground.
必要な工具と部品
Remove the finger plate. Start in one corner and push in a spudger/flat blade and lever it up. It is glued all the way along and has clips at the bottom edge so you'll want to bend out the bottom edge to clear the clips.
With the fingerplate removed, you can get a spugder in the bottom and lever off the backplate. Again it is stuck down with tape all the way round and has clips that break away easily. I don't suggest you do like I did and push a metal screwdriver all the way in, you could short out the battery. It is coated with some glue/lacquer, so maybe not!
The board is held down by some small (#0?) screws and the battery is stuck down with double sided tape. You will likely pierce the foil wrap when you try to remove it.
